Thanks for the plow help.
Roddo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roddo Quote  Post ReplyReply Direct Link To This Post Topic: Thanks for the plow help.
    Posted: 06 Jun 2011 at 1:43pm
I bolted on the cover boards and it didnt make much difference.  It helped but not much.  So i decided to go nuts adjusting etc.
I moved the coulters down and back, set the lift links a bit more so the plow sat slightly deeper on the deadfurrow side.  Lastly I made up a 2 ft long landside with a brace on the back bottom.
It works mint.  I don't even have to look back and check anymore.  I hope I can whip this little field into shape to plant some corn before it gets too late!
Teddy (punchie) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Teddy (punchie) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2011 at 4:45pm
Glad you got it to work,  we just planted 2.5-3 acres of sweetcorn today. All new plowed fields, The fieldcorn is all up planted a week ago tuesday and wednesday. Good Luck !!
Ac D-19, a Number of WD's, One WD45, Two 444 balers, Ac plows and etc.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2011 at 5:40pm
See what a little adjusting can do. I've heard many over the years say they have that trouble and blame the plow. Some bottom types are a bit fussier than others but as you proved they can be made to plow.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roddo Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2011 at 8:45pm
Well I disked the heck out of that little field and planted some corn.  I know its late but I don't have any other option.  I made a mess of a part of it where the plow wasn't working so well but the rest of it looks great!  Again thanks for all the pointers and advice.
