CA locked in 4th...
Wes (VA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes (VA) Quote  Post ReplyReply Direct Link To This Post Topic: CA locked in 4th...
    Posted: 05 Jun 2011 at 11:29pm
A friend of mine has a CA that got stuck in 4th gear, and then he was able to pull the shift lever in to neutral while still stuck in 4th.  Has only done this once.. he was able to get it out of gear without taking anything apart.  concerned, he pulled the cover off and we weren't able to see anything majorly wrong.. some wear on the forks, but I dont believe it to be major.  The ball of the shifter had been built up, but wasn't completely  round.  I'm sure its been discussed before, but what is the size of the ball supposed to measure?  May also build up the forks while we're in there.   Thanks -Wes
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2011 at 11:35pm
dont try to build up forks , just build up lever end until it fits into fork. measure the fork and the width of the ball end also.
JR Maley View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JR Maley Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2011 at 8:19am
Thats what you get for having a 4th gear.
WD in kansas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD in kansas Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2011 at 9:39am
My WD has this issue (like all of them seem to). I know the fix is to build up the ball and possibly the end of the shifter. Since I am not a welder or a machinist, I've often wondered if anyone on the forum rebuilds these? It would be ideal if somebody had sort of a "core" program... send me a good one and I send you my worn out one. I need the tractor for mowing pretty often.
1950 WD, Duetz Allis 613
Tedin NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tedin NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2011 at 10:56am
The ball on the end of the shift lever should be 5/8 in  diameter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD in kansas Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2011 at 8:04am
Bump ....... does anyone on the forum rebuild shifters?
Gary in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2011 at 9:01am
Try Bill at Sandy Lake Imp.
seems they offered to do the WC for me.
This page was generated in 0.168 seconds.
