Allis 600 planter
BiG210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BiG210 Quote  Post ReplyReply Direct Link To This Post Topic: Allis 600 planter
    Posted: 01 Jun 2011 at 1:16pm
Do you have to run stops on the wheel rams to keep the main fram from going down to far? frist pass I made the tires where off the ground but did not look to be running the notill and fert. coulters to deep.  thank you.
XT in pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2011 at 8:20pm
i use a 600 also and never had the tires off the ground. mine has a single acting hydroalic system on it [one hose] . i have liquid tanks on it that puts the fertlizer down right behind the seed boot. the no-til cultors ran in the ground but i think they need  adjusted down to plant no-til. the book says that cylinders need to be down all the way or you need to add more weight.
190XT,D17and 7045
