WD to WD 45
DVGWD48 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DVGWD48 Quote  Post ReplyReply Direct Link To This Post Topic: WD to WD 45
    Posted: 31 May 2011 at 8:38pm
Got a question, I have a '48 WD that needs an overhaul. A gracious fellow forum member gave me a wd45 engine also in need of an overhaul. My question is will the 45 engine fit on my WD frame? My assumption is yes but before I buy the rebuild kit for the 45 I wanted to make sure that there is not a compatibility issue. Thanks in advance.
Dennis(IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis(IA) Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2011 at 8:39pm
Yes
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2011 at 8:39pm
pretty sure it will. many parts are inter changeable
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Bob D. (La) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob D. (La) Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2011 at 8:54pm
If you don't look at the serial numberstampedon theblock, you wouldn't know it's a 45engine. Will drop straight in and bolt up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob D. (La) Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2011 at 8:55pm
If you don't look at the serial number stamped on theblock, you wouldn't know it's a 45 engine. Will drop straight in and bolt up.
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2011 at 8:56pm
Yes it will. A WD45 is a WD with some improvements.
When they upgraded the rear, hand clutch and engine they renamed the WD the WD45.
Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fields Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2011 at 9:16pm
Look for post on wd45 build ups. You can get a fair amount more power in a rebuild with little or no cost increase. If it is to be a "stock" type rebuild. I sugest E 170 or 175 piston kits You can also have the cam and lifters sent out to be reground for more power. Barney Taylor did mine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2011 at 9:23pm
Bob, You can tell a WD engine from a WD45 engine just by looking at them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DVGWD48 Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2011 at 9:49pm
Thanks guys for the information. I am sure I will have more questions as I do this rebuild.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2011 at 8:23am
Now.......if the WD block is in good shape, you can put the WD-45 components in/on it and it will look stock but still have all the power of the WD-45.
I would use the 45 crank for 1/2" more stroke.
Get the 1/8" overbore 45 pistons and sleeves.
Use the 45 "tall" head.
Use the 45 carburetor.
The tractor will look pretty much original; only the experts will know.
