A couple more CA questions.
Glockhead SWMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Topic: A couple more CA questions.
    Posted: 31 May 2011 at 8:07pm
I have a snap coupler 72 plow I plan on trying to pull with my CA. It is 14" bottoms. Anyone recall what width I need to set the rear tread at?
Also, anyone have a couple spare eccentrics for a CA laying around? I have one broken one and one almost round one. Thanks, Jesse.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2011 at 8:39pm
On 14" plows with the standard tires we ran the wheels all the way in.  Worked well for us.
Good Luck!
Bill Long
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2011 at 8:49pm
The CA is a great plowing tractor, you are really going to enjoy it. I set then tires so that the right rear would run in the furrow when plowing. When the plow is mounted, you can see where the right side tires should be (the point of the plow should be even, or slightly past, the outside if the tire. Can provide advice on how to set up the plow before you stick it in the ground if you want. Trust you have wheel weights or loaded tires; front wirghts are also a plus to keep the front tires on the ground when lifting the plow.
I have some CA eccentrics available; do you need the pin or the complete assembly?
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2011 at 8:51pm
Oops. Phat phingers again; the point of the plow should be even with the inside of the rear tire.
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2011 at 9:05pm
If you have 14" bottoms then your point should measure 14" to the inside of the right tire. Your depth and wing adjustments are best made in the field I've found. Winging the plow will cause it to ride with a flat bottom furrow. I have someone watch from behind to help me set up my plow. Depth can be made from the seat. I would make sure all the adjustmant points are free and easy to make over their full range before you attempt to plow. Makes life alot easier.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2011 at 5:39am
Yeah, I know how to set up the plow once I am in the field. I have already got the beaming screw loose. I plan on getting the winging adjustments loose this week one night. Never used this plow and tractor before so it should be fun. I have loaded tires and a set of wheel weights if I need them. Wish I had some engine weights too.
I need just the pin for the eccentrics. Someone snapped the head off of one of them and used a pipe wrench on the other.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2011 at 6:51am
I have some extras from parted out tractors. I will need to inventory today and see what I have.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2011 at 7:15am
I like wkpoor's explenation
