All-Crop operation question...
TomYaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Topic: All-Crop operation question...
    Posted: 31 May 2011 at 7:14pm
If one is experiencing wheat piling up on the draper before it finally travels into the concave as a big slug, what is the issue?  Reel is low enough...Manual says dull blades??
Roddo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roddo Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2011 at 7:49pm
Reel could be too low.  If its pushing too far down on the crop it will move it backward standing not lay it back on the draper.
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2011 at 8:11pm
I agree with Roddo. In wheat all the reel has to do is lean or direct the wheat back to fall on the draper. Reel is way to low.
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2011 at 8:38pm
You may be cutting it to low .Cut as high as you can without missing low heads. The less amount of straw the better therhing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2011 at 9:00pm
I respectably disagree with wfmurray. What about farmers that bale straw? AllCrops were designed to take it all in and rubber on rubber threshing with their huge seperator area gave award winning results. The reel is too low picking up bunches of wheat instead of gently pushing it onto the draper.
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2011 at 10:03pm
   Ditto on the reel is to low .
http://www.rumelyallis.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2011 at 7:06am
Thanks for the advice guys...
Ryan, it is possible to take in too much straw.  I had a heavy stand and cut real low..plugging up like crazy..wasnt going too fast either..
BTw, your bars are in...will be shipping yours out this week.
Tom
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2011 at 7:13am
My father would try to run the 72 allcrop we had as high as he could without losing any grain.Being dairy farmers the straw was as valuable as the wheat.If the wheat was tall enough they would bale what came out of the combine and then cut the standing straw with the sickle mower and bale that up also.Not every year,but if the wheat was tall enough and we needed the straw.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2011 at 7:23am
Everybody around here that combined oats, would run the combine high to eliminate extra straw going through the combine. Clipping the straw was done before baling as it was an important crop.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2011 at 7:56am
The manual says dull blades, they are referring to the bunches right at the sickle.  I'd leave the reel low, so it just clears the canvas, but move it back so it helps the wheat up the slick canvas.  If the wheat wraps on the reel, then you are too low with the reel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2011 at 9:55am
Wheat around the reel was not an issue...so you and Jim Palmer say keep the reel low....I sense a CONTROVERSY! LOL!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2011 at 8:43pm
I'm thinking your sickle sections would have to be pretty dull or your driving way too fast to have it bunch up on the canvas unless the reel is to low. The canvas has metal bars running across so they carry the crop up to the cylinder quite well.
