Corn Planter for Behind a B?
Protrucker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Protrucker Quote  Post ReplyReply Direct Link To This Post Topic: Corn Planter for Behind a B?
    Posted: 31 May 2011 at 4:40pm
What would be the best/easiest to find & use planter for my B?
Old horse drawn?
Some other pull behind?
Add a 3-pt hitch & get something for that?
etc.
I haven't actually got the B yet, but I'm supposed to be picking it up this coming weekend.
Harvey/pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Harvey/pa Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2011 at 5:09pm
 I planted a lot of corn with a B & a 2 row Oliver pull type planter. Back up, drop in pin & go...Harvey
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2011 at 8:25pm
The Allis Chalmers Planter for the B was a one row planter mounted on the cultivator frame.  Was mounted but was a hard mount since you had to take the shovels off the cultivator and put on the planter mechanism.
I have to day Harvey seems to have the right idea.
Take good care of my favorate when you get it.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2011 at 8:40pm
If you find an old 2 row pull type planter cheap enough, buy it. All the stuff on ebay has way crazy pricing for old 2 row planters. It might be cheaper to by an old 4 or 6 row planter and take a unit off and rig it for 3 point hitch. The problem with that is the guys that are already doing that for the people that want something for a food plot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2011 at 10:50pm
I bought an old 290 John Deere two row planter, I pull behind my WD. The 290 I have does not require hydraulics, the planter has a rope operated mechanical lift. I planted some with it this spring and it planted good. Plates are readily available too. I have a IH 455 planter that is 4 row for sale if anyone is interested. Pastor Mike
se iowa picker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote se iowa picker Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2011 at 10:56pm
A john deere 290 would be a good match for the b. I have one I plan on using with a c later on maybe next year to plant sorghum cane. Plates are cheap at farm sales for them too. 5 or 6 bucks for a boxfull is all i ever have paid.What ever you end with, good luck.
