8070 Air Conditioner
bugbird View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bugbird Quote  Post ReplyReply Direct Link To This Post Topic: 8070 Air Conditioner
    Posted: 30 May 2011 at 8:42pm
We are having some trouble with keeping the compressor belt on.  We have tried loosening and then tightening, but belt still either comes off or breaks.  We can't really tell what is happenig.  Does anyone have any idea that might help.  Thanks
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2011 at 8:50pm
I would ask, if the first belt that came off was it factory original? It's possible that over time it was replaced by a belt that may not be 'seating or riding' proper in the pully's. Or maybe at one time the compressor was replaced and that replacement may have the wrong width pully on it?  just a few thoughts that come to mind.
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2011 at 9:22pm
Belt problems like that sound like harmonic balancer problems.Can't say that's what's going on but bad things happen when balancers are bad.That's a viscous damper  and can look fine from the outside but still be bad.First obvious thing to check is it running perfectly strait and true?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2011 at 9:34pm
Replace the fluid filled vibration dampner......if you don't, you may have a broken crankshaft or broken main caps.....the air cond belt will be the least of your troubles.
