7000 ser odds and ends?
Chris WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris WI Quote  Post ReplyReply Direct Link To This Post Topic: 7000 ser odds and ends?
    Posted: 30 May 2011 at 4:29pm
Is there a good source for the rubber bumpers that belong on the hoods of a 7030 allis tractor.  I was told that is why the hoods don't stay on very well, the bumpers get hard.  I am also looking for the radiator seal foam that goes between the hood and radiator.
Troy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Troy Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2011 at 6:41pm
Chris, i lost your phone mumber , on the ring and pinion that you did not use, are you going to bring back sometime, i have the bottom plate for you and tachand fuel guage if you still want them. call me i just got a 7030 in for salvage also. 507 421 0213, troy
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2011 at 7:13pm
I replace all the bumpers or snubbers last year on my 7050. AGCO dealer had them in stock. Don't remember price.
Wink
I am a Russian Bot
redline View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote redline Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2011 at 9:58pm
foam kit for around radiator 70270115-not cheap through AGCO, but it will fit and work right.
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2011 at 10:32pm
 I just replaced both when I went over my 7060. The radiator foam kit was a little over $100, and the rubber bumpers I bought from Mcmaster Carr online and they worked just right. Thanks to someone that posted on here about Mcmaster Carr they have alot of things. I used to have troubles with my panels coming unlatched but knock on wood they havent since I put new bumpers on it.
This page was generated in 0.223 seconds.
