D17 diesel series 1
dan1714 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dan1714 Quote  Post ReplyReply Direct Link To This Post Topic: D17 diesel series 1
    Posted: 29 May 2011 at 7:14pm
I changed oil in the tractor a while back and know it leaks out the side of the filter. There is only one gasket on it and its tight. I have the same oil filter I have used for 7 years on it. I also tried a new gasket and it did the same thing. Any help would be helpfull thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2011 at 8:25pm
You don't have something under the gasket between it and the filter base do you?
Post Options Post Options   Thanks (0) Thanks(0)   Quote dan1714 Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2011 at 11:24am
no I cleaned it off
Kraig (WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kraig (WI) Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2011 at 1:11pm
Same thing happened to me. I cut another gasket out of gasket material and now have two gaskets in there and it works fine. Kraig (WI)
7010,D17D,WD45,WD,WC,WC,B,
Gleaner K,60,66,72
jasperalden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jasperalden Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2011 at 1:38pm
I'm new to AC tractors, I bought a D-17 from a relative. Does anybody know the approximate weight of one of these.
I haven't seen it, so all I know is that the motor is stuck and it's complete.
Wide front or narrow front, I'm not sure.
The price was great.
I have a 7,000 LB GVW tandem trailer. I'm hoping it will handle it.
Any help is greatly appreciated. I will be restoring it.
Thanks
Jeff
BCPuller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BCPuller Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2011 at 1:47pm
We had a problem like that once and the filter was bad. check that out
somebody View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote somebody Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2011 at 2:34pm
I think about 5200 lbs.
Tedin NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tedin NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2011 at 2:57pm
Shipping weight of gas tractor 5300 lbs. add for loaded tires
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2011 at 3:08pm
A 7000lb trailer would be pretty much maxed out. If the trailer has car tires, you would want to switch to an actual trailer tire.
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2011 at 8:37pm
Series I has a cartritge type filter. I have seen problems like this before. Could be a damaged cartritge or trash from the old gasket still in the base. I replaced my filter base with one off a 19. They use a spin on filter.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2011 at 10:52pm
I just had the same problem but thought it might be from the NOS filters that I am using. I finally let it set overnight in oil and I think the rubber swelled up a little and then when I tightened it down it sealed.  I think I might  put one from a D19 on it...it was a royal PITA! That little drain plug on the side was sure some bright idea, too....
ALLIS EXPRESS!
This year:
