Broke the Steering Arm Assy. on a D19
Teddy (punchie) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Teddy (punchie) Quote  Post ReplyReply Direct Link To This Post Topic: Broke the Steering Arm Assy. on a D19
    Posted: 29 May 2011 at 12:06pm
Need an ARM ASSY.  for a wide frontend D19. This part holds the two tie rods ends underneath the center of the tractor, and mounts to the  SHAFT (steering).  Has a splined center that mounts on the Shaft (steering) coming out of the steering box.
Question is what is a good way to get to this part? I'm thinking I have to take the frontend off.  The tractor is in a plowed field. Not the best place to work on it, on a little of a hill to boot.
P.S.
I don't have a part number, so if you do know or have a parts book let me know.
Thanks !!
Teddy
Ac D-19, a Number of WD's, One WD45, Two 444 balers, Ac plows and etc.
Ray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2011 at 8:46pm
I have the arm assy. 785-353-2392
