redneck cotter pin
redline View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote redline Quote  Post ReplyReply Direct Link To This Post Topic: redneck cotter pin
    Posted: 28 May 2011 at 1:04am
Probably one of the things I enjoy most about working with older equipment is seeing the repair methods that were attempted to keep the machine running for just a little while longer, or until the owner had a chance to get the proper repair parts. I have learned, though, that temporary becomes permanent. Whether it is a tractor fix or a fence or whatever.
I have seen all sorts of odd repairs, from nails and chunks of wire and other hardware serving as cotter pins, to wire wrapped around a pin to "build" it up to fit a worn bushing, I have seen barbed wire rolled up in snapping rolls on a woods brothers picker in an attempt to make it aggressive and all manner of clever ideas born out of neccesity. This is one I recently found:
anyone else care to share stories or photos of odd repairs?
rossinmich View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rossinmich Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2011 at 6:49pm
Seen a lot of nails used in place of cotter pins, also wire wrapped on the coulters to help with worn out bushings on an allis plow i recently bought..
dave63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave63 Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2011 at 6:56pm
Bailer wire and duct tape what else does a farmer need????
if you can't fix it with that you are not much of a farmer LOL
The universal answer to all questions is yes, how much do you want to spend?
mark-east-tn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mark-east-tn Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2011 at 7:04pm
With the dealer prices you have to do something to get a little relief.
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2011 at 7:28pm
Grandpa said once, the great thing about a Gleaner combine, was that all a farmer needed in the tool box was a few nails of various sizes, a hammer, crecent wrench, a roll of wire or twine, and a roll of ductape
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
acwdwcman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acwdwcman Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2011 at 9:46pm
If a cotter pin breaks or I loose it. I just use a nail.
wd with a freeman model 90 trip loader, wd45, 38 unstylled wc, b 10 garden tractor and 2-14 ac trip plow. grandpa has a 56 wd45. wd. allis chalmers snap coupler blade and 3 bottom snap coupler plow
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2011 at 10:02pm
We got a few redneck repairs around this farm. Maby Ill take some pictures and show you.
Walker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walker Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2011 at 10:48pm
Improvise man improvise.
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2011 at 2:06am
16 D nails work the bestest! also, when i hook up the plow, i use them hardened bolts outta engines (head bolts) instead of them snap pins...they hold their shape better and don't lose em in the field!
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2011 at 7:44am
Don't forget ZIP TIES in assorted sizes, even better than baling wire in alot of places!
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2011 at 8:29am
Epoxy
Robert Mull Georgia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robert Mull Georgia Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2011 at 8:33am
I have buggered the threads of a bolt with a hammer on purpose  many times to keep a nut from coming loose.
Bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bee Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2011 at 8:36am
axle nut shim cut from a roadside sign.
Bob, North Carolina
1949 B
se iowa picker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote se iowa picker Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2011 at 9:30am
That way of farming and machinery repair is the only way lol.We have had worn out shafts with nuts on the end of them with the threads stripped clear out so we tighten them as tight as we can and weld the nut to the shaft.Its shot anyway and we get a few more miles out of it before we have to replace it anyway.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2011 at 9:58am
When I took wheel bearings off my NF the shaft broke off where cotter pin holds nut on bearing.Last guy tack welded washer to center of shaft where cotter pin went.Worked so good I did the same thing when I replaced the bearings.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2011 at 10:57am
You give a red neck credit for that !!!! LOL
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2011 at 12:40pm
Being an Aircraft Mechanic by trade its hard for me to wrap myself around farming mentality towards maintanence. I guess when your life doesn't depend on it its acceptable but I just can't bring myself to do bailing wire repairs...
Edited by wkpoor - 29 May 2011 at 12:53pm
Claus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2011 at 12:52pm
When we got my 170 the roll pin in the throttle lever was missing and someone used bailing wire, quick fix.  Never understood why somebody would do stuff like that, a quick fix to get you by is one thing but how often do those quick fixes get left as good enough until your problem blows up?
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2011 at 1:22pm
$30.00 in gas for a 15 cent cotterpin.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2011 at 1:40pm
Thad about sums it up right there. Isn't that where ducktape was made famous? patching bullet holes on the wings of bombers in WW2?
German Shepherd dad
#WD234847
#WD88193
junkman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote junkman Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2011 at 2:12pm
Bought a semi a few months ago for scrap. it came out of a fertilizer plant so I figure they had a problem with the throttle spring breaking. they had substituted it with a couple of bungy straps. Wonder what the DOT would have said about that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2011 at 1:36am
had an old chev pickup once, broke the trottle spring, when dad had the sheller come to do corn, they broke for lunch, and low and behold, there on that there sheller machine was a spring that would work! and it did! but it sure messed up the sheller all afternoon! lol!
This page was generated in 0.058 seconds.
