Radial tire pressure
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Topic: Radial tire pressure
    Posted: 27 May 2011 at 7:58am
What is the proper air pressure for radial rear tires.  They 20.8x38 on a 8030 that will be carryring a decent amount of weight on the 3pt.
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2011 at 8:06am
Single or duals?How much is decent amount of weight?
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2011 at 8:22am
The duals go on and off.  Enough weight that a 6080's front touch very lightly at best.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2011 at 8:24am
10# for duals,16#for singles.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2011 at 5:20am
Bob is right if the tires are tubeless. If you have tubes , they should be natural rubber for lower pressures. If regular tubes the pressure will need to be higher or you will develop rubber crumbs and eventually the tube will fail.
This page was generated in 0.158 seconds.
