5030 will not fire
tjco99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tjco99 Quote  Post ReplyReply Direct Link To This Post Topic: 5030 will not fire
    Posted: 26 May 2011 at 9:01pm
Hello, im new to this forum and I have owned my ac 5030 for almost three years.
The other day I was tillin around my trees and it laboured down then backfired and quit. I noticed it was leakin oil so i pulled it over to the shop and had a look. It blew out the rubber seal around the valve cover. so fixed that drained oil, nothin was in the pan, shavings water, just oil.
I then tried to start it and nothing. Pulled the injectors out, got fuel. Glow plus are black and bulbed so i found some online and they are on the way.
I was talking to friend who is a mechanic and he said to try some ether. I did and when it got a sniff it quit turning over. It turns over now, but my question is where else does a guy look? Do I need to tear it down? Now I dont know very much about these units and up until now it was just basic maint. Any help would be great.  Thanks
ALLISMAN32 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALLISMAN32 Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 9:27pm
The compression on those little guys is awful high to be giving them a wiff of ether. Would strongly recommend not doing that anymore. While you had the valve cover off did you check to see that everything in the valve train was moving correctly.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 9:34pm
the labored down, backfired & quit is what concerns me. that sounds terminal. Test compression. And as stated above, compact diesels run a very high compression ratio, (21:1 or more) they don't like ether for sure! I might be picking up a 5030, so this has my attention. Good luck, Ed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tjco99 Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 10:56pm
when I had the valve cover off everything was moving and it sounded normal. I will have to get a tester for compression, but when i had the injectors out i turned it over it blew out pretty good. would the glow plugs have anything to do with it?  Thanks for the replies.
Oh yeah im done with ether!
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2011 at 7:03am
Backfired?  Maybe your timing slipped?  Did you happen to notice the position of the valves when the injector shot?
Post Options Post Options   Thanks (0) Thanks(0)   Quote tjco99 Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2011 at 10:55pm
they were all moving not sure exactly in what order they are supposed to do it.  I took some other advice and pull started her. it started but had a real bad knock. so i shut her down and pulled back into garage. its tear down time.
79fordblake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2011 at 11:29pm
How long did it run? Maybe it was knocking from the ether you sprayed in it?
When I was in diesel school the teacher would use a running engine as an example and spray some ether in it, sounded awful. I never use ether, it slowly but surely kills the engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tjco99 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2011 at 10:53pm
it sat for afew days so im sure the ether would have been gone considering it only got a quick shot.  Everything looks good on the top end, just working on the bottom. will the oilpan separate from the block. it looks like the pan is connected to the plate at the back of the motor as one peice. thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote tjco99 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2011 at 8:09pm
alright well if anyone can help me out on this or point me in the direction of an online service manual that would be great.
My problem is still the pan. After finding all the bolts, four on each side, two up front and two hidden nicely at the back about six inches up a crevice that was packed with years of dirt. It still will not drop! am I missing something here?
Post Options Post Options   Thanks (0) Thanks(0)   Quote tjco99 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2011 at 9:12pm
found an online manual and it says "to remove oilpan engine has to be remove and front and rear plates unbolted from pan".  I now need a lift......
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2011 at 2:24pm
diesels really do not 'backfire'  that is really a  gas term - since it made a loud sound, either a valve hung open,  or something reallly went bad. REmove  injectors and connect line  with injectors outside engine - do not put hands on tips and wear eye protection, then turn enging over - one can hear the whoosing sound of compression - the injector should spray at about the end of the whoosh - that is country boy troubleshooting - if intake , compression, power , exhaust  doesn't happen in that order it will tell you what is wrong.    Only thing I could suggest as in the past most do not know the fuel pump oil has to be changed at each engine oil change - no oil in the pump can cause gaulding......
Post Options Post Options   Thanks (0) Thanks(0)   Quote tjco99 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2011 at 12:31am
What is gaulding?  pan is off and i found both rod inserts from piston # 2 were gone and chewed up the crankshaft.  taking it to a machine shop in the morning. hopefully it can be saved and all i need will be new inserts and a gasket kit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2011 at 6:53am
Sounds like you spun a rod bearing. You'll at minimum need the rods to be resized with that turned crank. The one that spun probably won't be reuseable. Why did it spin? Oil level too low? Oil pump weak? Oil pump pick up tube clogged?
Post Options Post Options   Thanks (0) Thanks(0)   Quote tjco99 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2011 at 12:04am
dropped the crankshaft, block, caps off at a machinist today. should have some answers in a few days. Im going to clean out the rest of the parts tomorrow and check out the pump and pickup. the oil level was fine but i do need to find the cause. this is a very good learning experience for me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tjco99 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2011 at 11:50am
well I need two connecting rods oversize bearings and a head gasket, that my suplier cannot get. they can get me rings and all other gaskets
Post Options Post Options   Thanks (0) Thanks(0)   Quote tjco99 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2011 at 4:34pm
Does anyone know where a guy can find a motor for this tractor?  got prices for parts but its over 2000$, and they cannot be ordered. thinking used engine or new tractor. thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote tjco99 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2011 at 10:15pm
I got a lead on a couple of 5020 tractors. Do they and the 5030 model match up parts wise?  If I buy these would my 5030 be good for spare parts? thanks
