Wheel Weight Question.....
Protrucker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Protrucker Quote  Post ReplyReply Direct Link To This Post Topic: Wheel Weight Question.....
    Posted: 26 May 2011 at 3:17pm
Will Allis Chalmers C rear wheel weights fit on the rear wheels of a B?
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 3:35pm
if it is a late model B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Protrucker Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2011 at 8:07am
Please excuse my ignorance but, what do you consider "a late model B"?
The B that I'm picking up next week (if my new trailer comes in on time) is supposedly a 1946. Will the weights fit this?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Protrucker Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2011 at 8:20am
Here's the weights that I'm asking about. I can pick them up for about a hundred bucks.
dustinmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustinmo Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2011 at 10:20pm
the weights you have in the pic look to be B weights, and the wont fit on a C without some engeneering, so you should be good, he was talking about late mobel B as the ones with 5 lug bolts like the c and not one big bolt to nold the wheel center on, and a hundres bucks on the weights would be a deal
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2011 at 9:06am
The only engineering you need is longer bolts. I have been using the C weights on my B's for pulliing for many years. In this picture I did grind a notch because the bolts were not long enough to use the taper bushings I use when I have longer bolts thru the wheel. I use a piece of 3/4" pipe cut at the angle of the weights. The holes are in the correct place.
The bolts I had in this B was for a set of WD weights which also bolted right on without any changes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2011 at 9:30am
I think Fred was thinking about using the tapered weights on the inside of the B which might be a problem. I never tried to make any weight work on the inside of a B. On my C I use the tapered weight both on the inside and outside with two on the outside when needed.
Edited by Dick L - 28 May 2011 at 9:31am
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2011 at 11:47am
Like Dustin says, they look to be "B" weights and should bolt right on.
I suggest you "jump right on them"; that's a good price!
This page was generated in 0.158 seconds.
