Allis Chalmers D17
Blake_AllisMan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blake_AllisMan Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers D17
    Posted: 26 May 2011 at 10:55am
Hey guys I was just curious what were the differences between a Series I, II, III, IV D17. This might be a dumb question but our family has never owned any D series tractors. I have always thought they were a neat tractor and have always wanted to own one but it would be helpful to know what to look for. Thanks Blake
1941 C
1952 IB
1947 C
1955 WD45 SFW
1956 WD45 Diesel
1977 5020 4WD Serial Number 1
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 5:54pm
Series I,Series II,and Series III were basically same tractor with differences in paint (Persion I and II),Decals,front grilles,lettering and mufflers I believe. Series IV was much different,two way live hydraulics,3 point hitch was factory option,hydraulic controls on right side between fender and seat and oval muffler.Believe Ser IV had stouter drawbar on Snap coupler version than earlier models.Not sure on engine sizes,Ser IV may be larger,A little more HP anyway.Bigger heads?
Series I had metal seat and others were padded,not sure about Ser II
Later Ser IV had gone to 6 bolt front hubs
Edited by Pat the Plumber CIL - 26 May 2011 at 5:56pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 6:33pm
HP never changed through out the entire run. The main difference is the industry standard hydraulics on the series 4. There are some other mechanical differences, but they are pretty much minor.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 6:43pm
D-10 & 12 changed from 138 cid to 149 engine.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 6:55pm
D17 gas 226 except for the oiling system, was pretty much unchanged. The 262 diesel changed from a cannister to spin on oil filter, head mounted to block mounted water pump, a bypass valve was added to the oil line between pump and block, camshaft profile changed.
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 7:00pm
Oval muffler first appeared on series III, also the headlights were moved from the front of the tractor to the top of the fenders.
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 7:34pm
 And early D17's had the same drum brakes as a WD/WD45. Later IV had a disc combination.
Tedin NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tedin NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 7:47pm
Tractor Data Book says disc brakes startes with Series III
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 8:00pm
Don't believe too much that TD says, but they are right about the brakes, new brakes were efective at s/n 420001, which was the Series III break
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tedin NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 8:46pm
When did the D17 change from 6V to 12V ??
Dennynwil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennynwil Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 9:01pm
I'm sure that all D17s were 12volt system, positive ground.
