Help with CA overheat
JM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JM Quote  Post ReplyReply Direct Link To This Post Topic: Help with CA overheat
    Posted: 25 May 2011 at 9:56pm
A friend of mine bought a CA last year and while using it to cultivate it would overheat. He put a new T stat in it and also tried no thermostat with the same results. We took the head off and did not see any evidence of blow by in the head gasket. The head had recently been rebuilt, we sent it in to a machine shop and had them check it. They said no problem with the head. Water pump is spinning, fan is blowing air back towards driver, radiator seems to pass water top to bottom ok. We found that the engine was baldly wore out so we did a complete rebuild. I just got it put togather and running today, runs great, still seems to heat up fairly quike just sitting still idling. The guage went to 220, I used a infered thermo and checked temps at the water neck--208, at the top of radiator --208, bottom of radiator -- 170, engine block at water jacket 208, bottom of block  crankcase, --150. Did not boil over or even seem realy hot but it is not being worked yet. Also dont detect any exhaust or pressure in radiator. I tested the thermostat heating it up with a lighter and used infered to check opening, about 190. What is normal temp for a CA? Maybe this thermostat is to hot. What are we missing? My C that is rebuilt will only run 170 on a hot day pulling a belly mower. Thanks for any help, JM.
Boogerowen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boogerowen Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 10:09pm
Check your timing, if not timed right, will over-heat...
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 12:14am
Well with all you have done it must be the rad. I would have gone there first.
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 12:46am
Agree. Do do a simple radiator test just plug the bottom hole and fill the radiator with water. Unplug the bottom hole and the water should exit the radiator in one big gush with some force behind it.
If the water doesn't exit the radiator like stated it needs cleaning.
I'm sure you already inspected the radiator but make sure you can see through all the cooling fins.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 12:47am
When everthing is right even with a thermostat that engine should run pretty cool.
Teddy (punchie) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Teddy (punchie) Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 3:59am
We have a WD that if a pressure cap is used it over heats.  Try running without the cap on rad.  Make sure fan is pulling enough air, should hold a walmart bag on the grille.
Ac D-19, a Number of WD's, One WD45, Two 444 balers, Ac plows and etc.
JM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JM Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 5:50am
We did check the radiator for flow and it was ok, fan pulls air strong, tried different radiator caps. Still runs hot. What thermostat should it run?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 6:20am
The B,C,CA engine usually runs pretty cool. If anything you need to close the shutters if equipped to get it to warm up to operating temperture. With all the work you did, I would've had the radiator rodded out and tanked just to have it done. It sounds like a coolant flow problem to me whether in the radiator or the block. Did you nenew the water pump with the rebuild? Possible bad impeller on the water pump?  Just sounds like a flow problem to me....  HTH
Post Options Post Options   Thanks (0) Thanks(0)   Quote Teddy (punchie) Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 6:48am
We always test thermostats, old pot on the stove.  I would think you can run it without a thermostat.   We always cover the rad. in the winter to get them warmer. Keeps some of the cold air off of me.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 6:53am
Im thinking the same as steve, when you did the overhaul did you remove the sleves? ive seen a couple of WC's where the block was filled with scale around the liners specially 3 and 4
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 7:15am
All the thermostats I have purchased where 170F ones. Recommend testing the Thermostat in hot water (use your temp gage and a known one to correlate your gage); using a lighter only tells you that it will open.
Tend to agree with those suggesting coolant flow issues. All the CA's I have rehabbed ran cool; it would take a lot of work (plowing) for any to exceed 170F.
Start with a though flush of the coolant system. I like using TSP; however some of the auto store cleaners are adequate. Add approx 6 Tablespoons of TSP and fill up with clean water. Run engine at hi idle until hot, then for several more minutes. Drain and flush with clean water (again, run engine at hi idle until hot before draining the clean water). Repeat several times. Use both the block and hose drains. You can also "pressure flush" with clean water with a hose into the top of the radiator with the correct hose end. I am always amazed at how much gunk comes out. Again, repeat as many times as needed until you always get clear TSP/water out the drains. Then flush with clean water a few times to remove the residual TSP. During the flush, observe how the collant is flowing in the top of the radiator; it should be "rolling" over pretty good at the top[ of the radiator.
If still have issues with overheating, check out your radiator. Blow compressed air thru the fins to remove dust and staw that have collected there over the years. I have also had to immerse the radiator in a tub of soapy water (TSP) and agitate it to remove the crud that collects in the fins that did not blow out. Also check that the fins are open. Check the flow thru it as described as Jeff described (some times the repair people block off too many tubes to repair a leaky radiator). If possible, borrow a known radiator.
Still have issues? Then suspect your water pump or crud build up in the block and/or head that did not get removed from flushing.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 7:25am
You have all thoroughly diagonosed the problem.  I do agree that you should try to flush the block.  Sometimes if the radiator leaks it may be filled with stream water which could have some mud in it clogging the block.
As stated above the B,C,CA engine always runs cool.  If it is running hot there is something wrong.
By the way I love the tools you are using.  Pop would never have purchased them.
Good Luck!
Bill Long
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 9:18am
Could be mud gunk in the block but like Steeve said the radiator sure could need rodded. You can have seemingly good flow by just dunping warter on top and watchiing it come out the bottom. However it the center tubes are plugged where the fan pulls the most volume of air thru it can still over heat. You have to remove the top and bottom tanks to run a rod thru the tubes If the tube are plugged flushing will not clean them out. A blade/rod needs to be pushed thru the tubes to clear them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 10:32am
Timing and fuel mixture are probably the cause if block is clean. Tracy Martin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 10:37am
I agree with Steve and Dick. When I overhauled a 60 Oliver (about same displacement) I couldn't believe the amount of junk in the water jackets, especially around cyl #4.
With no thermostat, it should hardly move the temp gauge. My CA hasn't had a thermostat for at least 15 years. I always used the shutters to warm it up. First thing I'd do is have the radiator rodded out like Steve and Dick say. While the radiator is out, pull the water pump and have a look at the impeller. I've seen them rust away to nothing and hardly pump any water.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 10:43am
I had an old Chevy truck once that started over heating on me. I finally found out the impeller was wore down so bad it wouldn't pump water anymore.
Goose View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Goose Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 11:54am
I was thinking that, too. Maybe the water pump is worn so that it doesn't circulate enough water or cavitates. I'd try replacing the water pump and see what happens.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 12:53pm
I remember when I did my first B engine. After I had pulled the sleeves out, I couldn't believe the muck and sludge in the block that surrounded the sleeves. I filled a large pickle jar with all the muck I took outta' that block! Washed the block out, and it was still coming out. I was amazed to say the least. I don't know if that engine ever ran hot or not because when I purchased the B, the engine was stuck. I also had the radiator rodded out, and my radiator man said he could've started a small tomato garden with what came out of that radiator. Did the same to the IB Radiator to on the rebuild. Both Tractors on the hottest day pullin' the finish mower even get near the green zone on the repro temp gauge that sticks through the hood. As a matter of fact, its been a few years since I last back flushed the B's engine and renewed the antifreeze. I think I'll do that over the holiday weekend while I'm thinkin' bout' it....
JM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JM Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 9:24pm
Thanks for your respones. This engine was completely tore down and rebuilt. Block was hot tanked and line bored. I have the time set, carb dialed in. We are going to have the radiator rodded out, check water pump flow. We were told the pump was new, I checked to see that the impeller was spinning when I put it on. If that doesnt work I think we will have to do a carbon monoxide test in the coolant. I wonder if it is possible to get a crack from the exhaust port to the water jacket and not have any water in the exhaust. I noticed when I first started the engine and got it running straight, it did seem like the engine was building heat fairly quick. It ran about 20-30 minutes before it hit 208.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2011 at 12:04am
Wow. There's a problem somewhere there JM. Let us know how ya make out. I'm bettin' its a plugged Rad.....
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2011 at 8:22am
Could you some how or ever got a head gasket without the holes between the head and block.  Those head gaskets will bolt on end for end. I have a few new head gaskets along with a few engines blocks in my home shop. I never checked the water holes in the gasket when I laid a gasket on the block end for end. When you put them on end for end the gasket is slightly short on one end and slightly long on the other. That is all I ever look for. I had noticed in the past that the bolt holes line up both ways though.
This is only a thought.
Lightning took out my home computer so I would have to get Dixie to share to get on over the weekend.  Might not be back on until Tus.
JM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JM Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2011 at 9:54pm
I checked that too Dick, gasket can go either way holes line up not matter what way it is on. I did find out the water pump will hit the gasket if you put longer end up front. I hope it is radiator.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2011 at 6:42am
I just remembered that I have a radiator in my stack of used radiators that might get repaired some day that the baffle at the top to keep the flow from going out the over flow came loose. I didn't use that radiator on a tractor to know if it would have cause over heating but thinking about it, it might could maybe restrict flow thru the tubes to cause overheating. I had it on the tractor long enough to see that the water level would go down as it run at high idle. Still back to the radiator would need to go to a radiator shop.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2011 at 11:48am
I had a '65 F-350 that would overheat on the highway if more than ten miles from home. When I took the fan belt off, I could twirl the water pump shaft with my fingers and it would spin a few turns on its own. I suspect the water pump impeller had split and fallen off. It quit overheating with a new rebuilt water pump. That was on a 390 with 4 barrel carb and a 5.375 rear axle. I never didn't find out its towing limit. It had a small gas tank in the cab it couldn't pass a filling station.
Gerald J.
This page was generated in 0.191 seconds.
