How to get Cast centers off axles on a D19?
nowaktj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Topic: How to get Cast centers off axles on a D19?
    Posted: 25 May 2011 at 8:56pm
Hi guys,
I have the non spin out rims on this tractor.  I'm trying to get the cast centers and then the hub off so that I can replace some leaking seals on the axle bearing/axle housing.
How do you get these off?  I have removed the bolts between the cast center and the hub and it seems you use jacking bolts to pop these off of each other.  Did that...nothing moved!
What ideas have you guys seen work?
Thanks in advance
Terry
D19D, D17D, WD, WC, Snobee, #83 Plow, SC Blade, 14' disk, 400 series planter, B , Terra Tiger, M Dozer w/Baker Blade, TL-12, 42S Grader, G
den/southern illinoi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 9:22pm
Terry, Since I did not know any other way to convey a past listing to you, check out the subject I just brought back from the end of April.  It's how I got my D 19 wheels loose.  Its the subject of loosening the D 19 wheels the new way that is a subject or two below this one or at least somewhere on this page for the moment.  Den
Own 4 wheel 20, 2-5015, 5020 and associated equipment and 2 electric forklifts.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 9:25pm
Someone here used a jack hammer on a skid steer right on the cast center near the hub. Don't remember who but he said it worked great. I just turn each bolt until you think they will strip and then go around and just keep tweeking each a very very little. Too much on any one bolt and you will bend the bolt. You have to have the right bolts too. I have used heat before when I had already bent up bolts once and that worked with cruddy bolts but I would try a jackhammer before I did that again.
Edited by Lonn - 25 May 2011 at 9:31pm
Wink
I am a Russian Bot
Ray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 9:53pm
YOu need to use the 3 special bolts to  pop them apart. Works good. I have the 3 bolts for sale. 785-33-2392
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 9:57pm
Yes you need the special jacking bolts, I just moved mine the other day,
If you need you can call me
Matt
320-420-2752
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 11:32pm
 I would be careful using the jackhammer method, I would think it would be awful hard on the inner axle bearing or worse break the rear end casting out were the inner cup sets.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 4:10am
Jack it up so the tires off the ground -Tighten your jacking bolts up - tight- then hit the end of the axle with a big sledge ; should pop loose , JD even reccomds this method
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 8:21pm
Ya but that's about 3/4 of the procedures in a standard JD service manual!  :-D  I wouldn't even use my good sledge. :P
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2011 at 6:06am
What is special about these jacking bolts?  I used 3/4" bolts and then stuck a plate between the hub and the cast center.  Then, I tightend the bolts.   Nothing moved!  Do the jacking bolts do something special?  I am wondering if I am ever going to get these off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2011 at 6:24am
I have done that with the plates too ; when I bent + stripped  all my jacking bolts !!!! It works ;
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2011 at 9:45am
ALLIS EXPRESS!
This year:
Brad-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad-MN Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2011 at 10:58am
You pretty much have to have the jacking bolts to get those centers off the hubs....I tried and was defeated badly when I did mine, until I got a set of jacking bolts and used a big sledge hammer to loosen them.
1930 U
1938 A
1941 WF
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2011 at 4:57pm
Matt Mn-Thanks for the help today!  I had the casting off 5 minutes after I got home...no hammer needed!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2011 at 5:09pm
Howd you do it ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2011 at 5:29am
Hi Doug,
Jacking bolts along with some squirrel juice.  Matt gave me some good advice to slower tighten each bolt 1/8 of turn and it starting moving immediately.
Terry
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2011 at 7:08am
Do the jacking bolts have a diferent thread?
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2011 at 12:07pm
They are 3/4" course thread.  The picture by Eldon gives you a good idea of what they look like.
