3 Cylinder B
KenBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Topic: 3 Cylinder B
    Posted: 25 May 2011 at 6:52pm
My B wasn't firing on all cylinders all of a sudden. Tracked it down to #3, changed the plug and checked for spark but no change. Good compression but the plug was black vs. grey. Pulled the valve cover and one of the push rods was higher and to to the right side of the rocker arm. I also noticed that the rear rocker arm amd the front one aren't distributing oil down the groove to the contact face.  Also, the rear rocker arm of each pair isn't lining up with each valve.
Do I need a new rocker arm assembly? Can mine be rebuilt?  There is some side slop at the shaft in each arm. The engine was overhauled two years ago but I don't think anything was rebuilt here. Please advise!
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 7:09pm
 DO YOU HAVE A BENT PUSH ROD??? CALL1-574-342-4545
MBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 7:34am
No, push rod is straight.
This page was generated in 0.234 seconds.
