D-10 Power shift rear wheel...eccentrics STUCK
D10ACNC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D10ACNC Quote  Post ReplyReply Direct Link To This Post Topic: D-10 Power shift rear wheel...eccentrics STUCK
    Posted: 24 May 2011 at 7:23pm
In my effort to change the width of the rear wheels, I cannot get the eccentrics to move.  I can't get a socket to fit snugly on the 1/2" square drive.  I have tried a 1/2" drive extension reversed with a pipe wrench on the male end to no avail.  Anyone have any suggestion as to how I can break them?
Edited by D10ACNC - 24 May 2011 at 7:24pm
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2011 at 7:27pm
  take the wheel off an get a bfh is the easiet --1-574-342-4545
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2011 at 8:15pm
Like Norm says. Take the wheel off, lay it down, unbolt the clamps, and knock the center out with a sledge. The ecentrics are much easier to loosen without the pressure from the wheel on them.
Tedin NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tedin NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2011 at 8:43pm
Follow above, then you may need heat to loosen up. May be able to pound eccentric out. Also use penatrating oil
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2011 at 9:33pm
As mentioned above, best to separate the wheel center from the rim and unbolt the eccentrics from the center.  The ones on my D14 and D15 were so rusted that the cutting torch would not even loosen them.  I threw them in the wood stove for a day - worked great!  Everything came apart real easy after that.
Once apart, I sandblasted all of the pieces and put them back together.  Works really smooth now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote D10ACNC Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 6:53am
Originally posted by norm[ind norm[ind wrote:
]  take the wheel off an get a bfh is the easiet --1-574-342-4545
Hi Norm.  What's a bfh?
Post Options Post Options   Thanks (0) Thanks(0)   Quote D10ACNC Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 6:55am
Thanks for all the replies.  Looks as if I'll need to take the wheel off for sure.  Wonder if that power shift worked well when new?
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 7:20am
Big Fit Heman
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 8:32am
Link to a previous post (with pictures and good instructions) on this subject. Patience and persistance will save the eccentrics; heat and extensive force can ruin them.
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 8:38am
Greg is exactly right.  Excessive force can ruin them.  I am living proof that long cheater bars are NOT the correct tool.
Bull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bull Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 9:57am
I had the same problem on my CA. I placed a 1" socket 1/2 inch drive on the eccentric. I welded a bolt into a 4' length of pipe, placed the bolt into the socket, once it moved a little I worked it back and forth until free.
Glockhead SWMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 11:43am
I have a set of square drive Matco sockets and a breaker bar that works well. I ussually soak them in penatrant and beat them with a hammer a few times. Most times they break loose pretty easy. The smaller 1/2 drive D series and CA will break though. One on my CA is snapped off.
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 12:47pm
I take mine off like mentioned and then remove the snap rings and press the pins out. You can press them out long before you can turn them.  Dave.
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 7:30pm
  THEY WORKED OK WHEN NEW AN NOT FULL OF DIRT AN GRIME
Post Options Post Options   Thanks (0) Thanks(0)   Quote D10ACNC Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 7:37pm
[/QUOTE]
Big Fit Heman[/QUOTE]
????   Still unsure!
Post Options Post Options   Thanks (0) Thanks(0)   Quote D10ACNC Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 7:38pm
Great suggestion, Greg.  Pictures always help.  Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote D10ACNC Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 7:39pm
Great idea.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 10:44pm
Big Flippin' Hammer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote D10ACNC Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 5:22am
Ha, ha.  Thanks Dave.
