Need help no one seames to know
Vinnie/S.D. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Vinnie/S.D. Quote  Post ReplyReply Direct Link To This Post Topic: Need help no one seames to know
    Posted: 23 May 2011 at 10:02pm
Ryobi CS30 grass or weed trimmer //// The magneto tester showes it is working BUT it has not got enought power to make the spark plug fire ( 2 new plugs) I can hold it about 1/16of an inch from the frame  and it will give a little ark of fire any more and it wont. What is wrong??? The big boys at the shop dont know
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2011 at 10:09pm
Sounds like the coil assy is faulty. Most of them that small are totally self contained in the coil. A new coil will usually be close to the price of a new one...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2011 at 10:15pm
Throw that pos away and buy a Stihl. Daughter has one. I have to go online just to get a spark plug. I have a Ryobi jointer/planer; can not find replacement blades anywhere. I don't plan to ever buy another Ryobi product.
RickUP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RickUP Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2011 at 2:17am
I had a Ryobi trimmer. Had to throw it away. I am looking at Stihl or Johnsered.
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2011 at 4:52am
if you are holding the plug away from the cylinder not allowing it to ground, it must be the mag does not have enough umph to throw the soark. if it will jump with a gap, but faint, it is probably the solid state trigger built into the mag. i have a ryobi trimmer and use the heck out of it. if i could afford a stihl from the beginning that is what i would have.
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2011 at 8:05am
If you are suspicious of the compression, you might check for the heck of it.  Mine is 120.
Sometimes I hve seen where i thought the spark was too weak but when I put the plug in and yanked on the cord they fired right up.
The only problem I have had with mine is that it just won't quit.  I have a tiller, brush cutter  and edger attachment that I use on it also.
This page was generated in 0.110 seconds.
