Need help
RAUCHOHIO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RAUCHOHIO Quote  Post ReplyReply Direct Link To This Post Topic: Need help
    Posted: 22 May 2011 at 9:36pm
I have an H3 That I have been restoring. Recently when I have been using the H3 it operates just fine except the right track. It started to not work properly. I can run straight just fine. When I pull the right drive clutch and hit the brake I turn right like I should but the stick is harder to pull than normal. When I pull the left stick and hit the brake to stop it sometimes the right track stops as well. Some times it will work for a few seconds. It acts like it locks up. At times going up hill the right track stops  and only the left track is moving causing me to turn right. When I get up to a heavy push the left track moves and spins trying to push the pile but the right track stops. I am assuming the clutches in the right side are bad. I have never had them apart yet. I replaced the brake bands but did not remove the clutches. Any help or ideas would be great.
Thank you,
