Giant aerator thing?
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Topic: Giant aerator thing?
    Posted: 22 May 2011 at 8:24pm
What are they? They look like a disk, with long metal rope like strands that look like what you would find on a lawn aerator. I asked grandpa once years ago while we where following one near Hastings, MI. He called it a mouser?
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
MBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2011 at 8:16am
Hoe.
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2011 at 9:48am
rotary hoe
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2011 at 10:57am
If it rains on a field right after beans are planted and then dries out fast it will form a hard crust on top where the beans cannot push through the crust.  If another rain is not going to come soon to soften the crust we would use the rotery hoe and run it over the top to bust up this crust to allow the beans to pop out.  We could run it pretty fast over the field at about 10-12 MPH.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2011 at 4:00pm
No, It hade more of the frame of a tandem wing disk. I'll look on tractor house and see if I can't find one. He also said they where used in muck fields.
German Shepherd dad
#WD234847
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2011 at 8:09pm
Maybe a pasture renovator?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2011 at 8:17pm
My neighbor used some kind of rolling basket thing to go over bean ground, before planting last year. It was a single row and veed so if you took the whole width of the implement every pass it made ridges across the field. Kinda like this.
wheatbreeder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wheatbreeder Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2011 at 8:20pm
Not rotary hoe pasture renovator  or early aeroway for wheat stubble to be no tilled instead of plowing
Morley
Farm stuff 8050,6690,175,F2,5050,WD
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2011 at 8:20pm
The blue one is the one! exactly like it 'cept the one I saw was CAT yellow.
German Shepherd dad
#WD234847
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2011 at 9:36pm
It is used on notill ground to rough up the ground in spring so ground will warm up sooner. If you don't disc or field culivate the ground the notil ground will be insolated from the rasidu left on top.   MACK
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2011 at 9:48pm
I think what your talking about is a phillips harrow. Its used to dry out ground ahead of the planters, knock down corn stalks ,or level anhydrous ridges, and like Mack said fluff up the residue. Around here you either have a pheonix harrow or a phillips harrow. All I use my 7060 for is pulling a 42' pheonix harrow and the faster you pull them the better they work. I try for 9 mph. Heres a picture of a phillips harrow, and my pheonix harrow.
Edited by 7060 - 23 May 2011 at 9:51pm
