Heating a shop help please
AC1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC1 Quote  Post ReplyReply Direct Link To This Post Topic: Heating a shop help please
    Posted: 22 May 2011 at 8:18pm
I have a 40 x 60 pole barn with 12 foot ceilings that I plan to insulate and add a concrete floor.  I just want some basic heat up to 50 degrees or so in the winter.  Any advice as to the most cost effective heat to install but yet keep my monthly heating bills reasonable as well????
paul s. mn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote paul s. mn Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2011 at 8:39pm
go with geothermal, pex tubing in the floor.more money to install.but cheaper to heat with. farmer .down near sleepy eye mn.has a bldg. about 60x90 heats and cools with geothermal for about $ 50.00 a month year around
Tedin NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tedin NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2011 at 8:40pm
I use an oversized forced air heater, because I can turn it up and heat the air in 30 min. Sometimes I only get a couple of hours every other day to work. In between I leave the heat low or off.
Allen Dilg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allen Dilg Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2011 at 9:08pm
  Hello AC1   Natural Gas forced air [house furnace]   40'x60' shop & [ 22'x40']  welding shop stays 37 degrees @ 0  15 min to 50  water etc don't freeze and I DON'T GO THERE EVERY DAY!!!!!
Rayhowling View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rayhowling Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2011 at 9:12pm
I built a shop 40 by 40 with a 16 foot ceiling 1997 and wish I would of put in floor heat. I built a furnace out of a 3 foot propane tank. Walls are 6 inch insulated and 8 inch insulation in ceiling. It doesn't take much wood to heat it. We have furnace on and if we don't fire it up for 2 days it still is above freezing. Fire it up and half hour or so and it is over 60 degrees.
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2011 at 9:49pm
About 10 years ago, my cousin and I put a floor in his pole barn, about the same size as yours, we put down foam board insulation on top of the crushed rock, pex tubing in on 24" centers, tied to the rebar, built a manifold, and installed two on demand water heaters for houshold use.  I didn't know any better, but he wanted two to be sure I guess, we insulated the heck out of that building, something like 14" blown in above the ceiling, and walls were furred in with 2x6" full of insulation.  Insulated roll-up doors. He only ever uses one of the heaters to keep that building at 60 degrees all winter, the only time I have ever heard of the 2nd heater kicking in, is if it is subzero, and blowing like crazy out side for days on end. Once you get the slab warm, it burns a failry small constant amount of gas to keep it that way.
The best part about infloor heat, is when you are working under a truck or tractor or something.  Since heat rises, most forced air shops never really get heat down under what you are working on, not so with slab heating.
Edited by Orange Blood - 22 May 2011 at 9:52pm
Still in use:
se iowa picker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote se iowa picker Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2011 at 10:37pm
Working on a warm floor sure beats working on a cold one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2011 at 10:43pm
Like others have said hard to beat a warm floor.I would at least put the piping in floor.Red pex tubing is inexpensive to install.Forced air is OK if you won't be out there on a regular basis.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2011 at 12:08am
I would bet with good insulation, in floor tubing and the geothermal system, you could keep the whole building at 45 degrees without using any other heat source. After the initial input costs, all it would cost to keep it 45 would be the electricity to pump you coolant down in the ground and back through the lines.
 My brother built a new house a couple years ago and put pex tubing in the basement floor. He said if he could do it over, he would add about 8 inches of sand on top of the insulation before pouring the slab, just to add more heat sink to the whole thing. It would take a lot longer to notice a change in temperature if he lost power.
Edited by CTuckerNWIL - 23 May 2011 at 12:16am
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2011 at 2:03am
<<<<agree with above replies...also i put a barn door track on one of the rafters, mounted a 2x6 piece on several rollers, attached a heavy tarp to the 2x6 pieces, i can roll it up against the wall, or close off part of the shop to contain the heat better. works great! i also close it when power washing or painting, keeps the mess in a more remote location!
randy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2011 at 6:40am
I put a radiant heater, a tube heater in last winter, it heats the equipment and keeps the floor warm, but if i was pouring a floor flor heat would be hard to beat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2011 at 7:38am
Like those that have and us dreamers, infloor heating is a MUST. Even if you don't have the coins for the heater/plumbing part now, put the PEX in the floor. You have ONE chance to do it right. NOTHING is nicer on old bones than warm concrete.
I have an 80,000 btu forced air furnace in my 2 car garage/shop and it don't get the floor warm ! Yeah you can be in a t-shirt 4' off the floor, but down where the real work gets done it's cool or cold.... Radient would be my second choice IF I had the height,but I don't...sigh.... oh for that perfect shop...
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2011 at 8:41am
I have a solar heater for my shop. Works great in the summer.  The winter time, not so much.
craigreavley View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote craigreavley Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2011 at 9:28am
I put in a woodburning furnace to heat my shop. I have a limitless supply of firewood, so after the initial 1500 investment. I heat the shop for free. At zero degrees outside I have had my building 70 degrees inside. I put old remnants of carpet on the concrete so i dont have to lay or stand on a cold floor. My shop is 36 x 80 with 12 foot ceilings. Only problem is that it take a couple of hours to get it warm If you just start the fire. For free heat I can live with it.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2011 at 10:46am
In floor heat is great if someone is going to be out there every day but if the day comes where your only to be out there once in a while, or gone for the winter, it will need to have antifreeze in it or be drained.
The 4" tube radiant heaters are a very good comprise. They are like the sun. They heat objects, even the floor, if it is a direct line of sight. Like a furnace they can be turned up and down.
I have one in my sheet metal shop, I've found that if I turn it down to below 45* then the steel and my snips are too cold to hold with bare hands. So I keep it at 48* and turn it up to 58* when I'm working out there.
According to the manufacture you can get them to burn natural gas, LP gas, and even fuel oil.
Dusty
dave63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave63 Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2011 at 8:03pm
Never poor a floor without tubing. put vapor barier down, then 2" of foam insulation, make sure you insulate the perimiter. lay the sheet reinforcing wire down. the rolled wire tends to not lay properly and the tubing may get to close to the surface. zip tie tubing to the wire and make sure that when the concrete is poured it is 2" from the surface.
Geothermal will definitly be your lowest cost to operate becouse you do not buy the energy that you need for heat. You only buy the electric to move the energy into the building.
installing Glycol in your system is no big deal [antifreeze] but i think you will find it cost affective to just keep it on all the time.
you will never regret radiant floor heat.
The universal answer to all questions is yes, how much do you want to spend?
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2011 at 9:07pm
In floor heat plus use spray  foam 3 inches in the walls and 2 inches of foam below the cement pad. At least R40 in the  ceiling.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
jhid View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jhid Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2011 at 9:32pm
We have a radiant tube in our garage and it works great, the floor doesnt get too cold and it heats up fairly quick
red and green are nice for christmas, but orange is all year round
http://www.canadianantiquetractor.com/tractorforum/
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2011 at 12:54am
Vapor barrier, 2" EPS foam, concrete with PEX tubing... and add any heat source you want... electric or gas water heater... a wood-stove with liquid heat exchanger... solar panels... whatever you want, whenever you can.
The other big advantage of heated floor... you can set the interior temp however you want... the floor will be warm... open the overhead doors and let a blast of cold air fill the building.  Close the doors, go back to work, and you won't feel a bit cold.
Finally... condensation.  Warm floor eliminates it.
My 'old' workshop has a concrete slab, and I can set that overhead furnace to 75F, let it cook for a day, come in there, and that slab will still be cold enough so that carpet simply won't fix it.  I was introduced to tubing-in-floor 10 years ago, and I've never poured a concrete floor since... without tubing.    My south porch (where I"m sitting right now) is a semi-passive solar collector during the winter... dyed dark black, and only gets direct sunlight between autumnal and vernal equinox... I run water through the floor, and direct it to the basement to move solar heat to the north side of the house... but during summer, I trickle cold well water through it to cool the house.  Man, it works.  I even put down an insulated barrier floor using lime and a plate compactor, embedded 1/2" pex in there, and put PAVER BRICK atop it in my wife's garden-shed / hen-house... and I heat that floor with an ordinary 1500w ENGINE HEATER and a surplus 1gpm electric pump, both controlled by a cheap thermostat and a relay.  Set to 50F, it never freezes, and the hens don't need as much food.
Oh, and no worries about anything freezing... I use propylene glycol.  100' of 1/2" pex is about a gallon (it's 0.0092gal/foot)... and propylene glycol is about $2.50/gallon.  Propylene is the pink stuff (RV anti-freeze)... non-toxic, and good to temps well below what you'd ever find in an insulated workshop.
This page was generated in 0.192 seconds.
