AC7 Turbocharger
Larry F View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry F Quote  Post ReplyReply Direct Link To This Post Topic: AC7 Turbocharger
    Posted: 22 May 2011 at 3:38pm
Can I use the 74029309 Turbo in place of the 74027204.  The manual calls for the 27204 which I can not find.  I have located the 29309.  The 29309 is for a later serial nubered engine.  This is on a AC 7gb craller.  This is information from the manual. The engin serial number is 3D12351.
Thanks in advance.
Dnoym N. S. Can. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dnoym N. S. Can. Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2011 at 5:48pm
UA33002 Turbocharger
New T04B90 Model
Replaces number D4029309, 74029309, 74029207,
74036513, 74062751, 84062751, 409080-5009
Includes Mounting Gaskets
(T04B90 Model)
Fits: 7030, 7040, 7045, 7050, 7060,
(210, 220, D21 Air Research Replacement)
BOLT ON REPLACEMENT FOR AIRESEARCH.
IF REPLACING RAY JAY TURBO, LINES & AIR
TUBE NEED TO BE CHANGED OR MODIFIED.
   Larry i could not find anything on that
tubo number 74027204.maybe someone
else can help you
hth    B:-)       Dnoym
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2011 at 9:21pm
If your old turbo is an "AirResearch" brand it probably has a V-clamp holding the compressor housing to the center section. The newer AirResearch turbo doesn't have the V-clamp, but is bolted. They will interchange with a little hardware modification on the oil lines and the rubber hose that connects the air inlet (newer turbo is about an inch shorter). If your old turbo is a "Thompson" or "Rajay" brand, the newer model will also work but you will have to be more creative on your oil lines.....like maybe use a hose for oil return and make a supply line from copper tubing and brass compression connections and fabricate a crossover tube to the intake manifold as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry F Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2011 at 9:39pm
DrAllis
My Turbo is bolted and has no V clamp.  It sounds as if it may have had a new tubo installed at some point.  It appears as though the 74029309 replacement will work and I may or may not need to modify the air and oil line.  Thank you for the reply.
Larry
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry F Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2011 at 9:41pm
DrAllis
In addition the old turbo is an Airesearch with no v clamp.
Larry
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2011 at 10:00pm
Then, they may be indentical except for the exhaust housing size/ratio....usual size is a .96 A/R and other sizes make be .84 A/R or .81 A/R.....the smaller numbers are tighter and allow the turbo to "spool up" at a slower RPM. Farm tractors use .96 and spool up at 1700 RPM and high idle at 24-2500 RPM. The size number is stamped on the exhaust housing somewhere is you are able to read it....sometimes inside where the exhaust housing bolts to the manifold.
groanwow View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote groanwow Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2012 at 1:10am
My knowledge about turbochargers is very poor...thanx for the great post...
It was very informative and useful....
