Outback S Lite
randy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Topic: Outback S Lite
    Posted: 22 May 2011 at 7:53am
Any body have one of these? Been looking at one, wanted to know how they work. I have a Teejet Centerline 220 and not real happy with it. Thanks Randy
wheatbreeder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wheatbreeder Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2011 at 10:06am
I have a Teejee Centerline 220 also what problems have you experienced
Morley
Farm stuff 8050,6690,175,F2,5050,WD
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2011 at 11:38am
It will work ok and then a cloud goes over and i lose signal, also the display is blurry when it gets warm in the cab. Maybe the antenna is going bat, it should work when its cloudy.
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2011 at 4:41pm
Randy, I run an Outback S and an Outback 360. They have been good units for me. It takes a while to get use to having both the position bar and the steering bar, but after you do it makes using them pretty nice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wheatbreeder Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2011 at 6:54pm
Randy
 I started spraying wheat yesterday the first 16 acres it was variable when I started the last field 25 acres it was dead on. It seams like it needs a warm up time
Morley
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2011 at 8:09pm
When i get a signal it works good, but it seams like a couple of clouds go over it louses its satelite. I have 2 other receivers on the cab that never seam to loose there signal. Guess i will call teejet and see what they say.
Kevin(Alabama) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin(Alabama) Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2011 at 8:31am
I have a teejet 220 and have not had the problems that you are having. For the money it has been a good guildance system. But I would like to upgrade to a mapping system
"I would die a thousand deaths before I would betray a friend."...Sam Davis, Nov. 27, 1863.....DEO VINDICE
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2011 at 10:04am
We have a teejet 220 and it sitting on the shelf because we did not have any luck at all with it, it never worked right. We had it worked on a couple times and it still dosent work right.
Now we got a Ag Leader 250 and are very happy with it.
