Crawler parts
maxalley View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote maxalley Quote  Post ReplyReply Direct Link To This Post Topic: Crawler parts
    Posted: 20 May 2011 at 9:13pm
Hi I am new to the site.  I recently decided to get out my dad's crawler tractors.  We used to farm with them for years.  They have been parked awhile all for something different broken.  I threw some batteries in the HD11 and it started right up and I drove it over to our shop.  Where is the best place to buy parts for these things?  AGCO have any?  I also have another HD11 dozer, a HD15 and a HD16.  Most will start right up.  Any help would be great.
big al View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote big al Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2011 at 9:57pm
it depends what you need,some things like the engine you can get from agco,fiat,or aftermarket.other parts i get from a guy that has allis and fiat-allis salvage yard in the northern part of michigan.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2011 at 10:04pm
Depending on your location will depend on supply.
Fiat-Allis construction is now New Holland Construction which is the old AC so their dealer network will handle most things . Minnpar in Mpls MN may have some things also in new parts. For used or aftermarket Thill Track and Tractor in Eau Clare WI is a good source. Lot of other places around also dealing in salvage and aftermarket things.
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2011 at 5:55am
I am still have some good used HD11 parts for motor, transmission,stering cluch,final drive,rollers,idlers,sprockets and more
Post Options Post Options   Thanks (0) Thanks(0)   Quote maxalley Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2011 at 10:09am
I am located in Arizona.  I appreciate the help.  I was just looking for where to get general parts.  I do need seals or a new water pump for my HD16.  I fired it up and it is leaking pretty bad.  Other than that the engines are all good.  just some transmission issues.  I am also looking for the Be Ge pump adapter for the HD11.
Tad Wicks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tad Wicks Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2011 at 10:49am
Talk to Carl at Fresno Tractor  559 233 2174, they have  "new" and quite a few  AC's for parts. Tad
Post Options Post Options   Thanks (0) Thanks(0)   Quote maxalley Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2011 at 10:56am
Thanks for the help Tad.  I will post picks of our machines when I have a little more time.  Our HD-15 has a Detroit in it.  I believe it is factory.  That thing so loud between the motor and the tracks.  Hopefully I can get them all up and running again.  I am tired of all these new computerized tractors.  I even have two TD18 and a TD 20 International crawlers that I would like to get running.  Those are last of course.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tad Wicks Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2011 at 11:03am
max, check out my ''11''  farther down the lineup on this forum. Tad
Post Options Post Options   Thanks (0) Thanks(0)   Quote maxalley Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2011 at 11:12am
I was just looking at that.  That is a cool machine.  Both of mine have the turboed allis engine.  The paint is a little faded on ours but they are in fairly new shape.  My dad rebuilt a lot of parts before they were parked.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2011 at 11:21am
motor and year of hd16 will make a huge difference
62ish or newer and you can probably get most parts for 17000 and newer engines through heavy equip dealers and engine parts suppliers...
older 16000 (3 valve)  and HD844 (2 valve) buda lanova engine not easy to come by
good luck
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2011 at 10:27pm
Good luck with your Allis crawlers. I have (2) HD-6's that are running but intend to restore.
Post Options Post Options   Thanks (0) Thanks(0)   Quote maxalley Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2011 at 11:50pm
How can I tell what year the 16 is?  Is it in the serial number?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 9:10am
1955  101 to 1008
   56   1009 to 2462
   57   2463 to 2756
   58   2757 to 4143
   59   4144 to 4725
   60   4726 to 5097
built until 1970 and last  #9619
