Off color but need help.
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Topic: Off color but need help.
    Posted: 20 May 2011 at 9:09pm
Our Farmall super mta has been acting up for awile. This in what its doing, most of the time it starts up good but sometimes it will start to fire and then it will stall you could crank it for the rest of the day but it wont fire again. But if you you pull it with another tractor it will fire it right up. It gets gas because you can see it blowing out of the exhust. Its a pain if there is no other tractor around to help out so this needs fixed.
Any ideas?
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2011 at 9:12pm
Gas mixture to rich, or lay off the choke. sounds like it's flooding, or not getting spark
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2011 at 9:16pm
This tractor never gets choked because, well it dosent need it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2011 at 9:19pm
sounds like the mixture is too rich then. pulling it gets it to roll over fast enough to clear i out and fire. could be a number of things though. need to know what you have and haven't checked?
German Shepherd dad
#WD234847
#WD88193
Troy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Troy Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2011 at 9:20pm
sounds like maybe your starter has to much draw, hook a hot wire up to the coil from battery and see if starts bypass the resistor, this will give full 12 volts to coil. if works your starter is drawing to much current away from ignition
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2011 at 9:23pm
Anther possibility I didn't think of. Like i said, we need to know what you have and haven't tried, or we'll get no where
German Shepherd dad
#WD234847
#WD88193
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2011 at 9:43pm
I wonder if the coil is getting tired.  When you're pulling it, the battery voltage is higher than when it's also turning the starter, so it starts.
I suppose your battery could be getting tired also.
Mark
GTH-L Simplicity
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2011 at 5:35am
A battery on the edge of going bad will do this also. You have to eliminate one thing at a time until you find the gremlin.
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2011 at 7:59am
We have tryed a few different batterys, but it still did the same thing.
Rogers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rogers Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2011 at 8:25am
I would consider changing the coil since you have already tried several batteries. Also  when was the last time it got new plugs and points? Since you don't believe it is a problem caused by a rich gas mixture or flooding I would lean toward changing the coil and installing new points. This is cheaper than looking at a problem with the starter. It could be there, but I'd look somewhere else first.
Think for yourself and be your own expert. Be willing to change your mind; however, willingness to change your mind doesn’t mean that you will. Blindly following any path is the pinnacle of insanity.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2011 at 8:42am
It sounds just like my Oliver 60 used to. I converted to 12V. It would crank fine, but no start until the starter button was released. It would light right off every time. Turned out the battery had a bad cell. Cranking voltage was dropping to around 7 volts. Plenty to crank the engine but not enough to spark under compression. You might put a volt meter on the hot side of the coil and see what it does when it won't start. Less than 9.5 volts usually won't fire a 12v coil under compression.
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2011 at 8:47am
Well its got new points and the plugs look great and the starter was rebuilt about a year ago. Im thinking it might be the coil going bad...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2011 at 8:57am
It could be a bad coil. Do a little detective work first so you'll know and only make 1 trip to the parts store. If you have a lack of voltage to the coil, it will look like the coil was at fault. If you find low voltage, do what's called a "voltage drop" test. Its simple to do. All you need is a digital meter. Simply parallel the circuit with the meter. Bad connections cause resistance and resistance can use some of the available voltage. Get enough unwanted resistance, and the circuit won't work. You can test the whole circuit first. If you find more than 1/2 volt drop, test each part and section of wire individually.
Edited by Brian Jasper co. Ia - 21 May 2011 at 9:01am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rogers Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2011 at 3:13pm
Brian is right bad connections really hurt an electrical system. Make sure all the connections are good. You have good points, plugs and battery. You might want to check the rotary button and cap although I don't think they would cause your problem. If the connections are good and you still have problems I would replace the coil if it were me.
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2011 at 8:29am
Well I think I got it, I had to fix a couple wires and put in a different battery and it starts up good now! Thanks guys!
Edited by R.W - 28 May 2011 at 8:29am
This page was generated in 0.168 seconds.
