duals?
landpainter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote landpainter Quote  Post ReplyReply Direct Link To This Post Topic: duals?
    Posted: 19 May 2011 at 7:29pm
Hi,Just looking for opinions on T-rail vs clamp on what do you think is better?
Claus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2011 at 7:43pm
Never really been around T-Rail duals but wouldn't they put more weight/traction on the dual with the extra cast center?  Plus the ability to change spacing.
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2011 at 8:02pm
T-rails are a type of clamp on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2011 at 8:09pm
These are T-Rails to me, i would not consider them a clamp on dual.
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2011 at 8:49pm
You cant really tell from the pic but these are T rails to me the clamps ride on the T rail that clamp to "eye" bolts on the inside wheel.
Edited by R.W - 19 May 2011 at 8:51pm
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2011 at 8:51pm
This is a T-rail.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2011 at 8:52pm
Your the first to call those t-rails.  T-rails have a T shaped rail that runs parrallel to the spacer band that allows you to not have to line up a certain spot on your dual to your eyelet.   T rails with snaps are a very good combo.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2011 at 8:54pm
Been wrong once before, guess it's twice now.
Dipstick In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dipstick In Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2011 at 8:56pm
Once again RW is right, his are T-rails. Don't know what those other rascals are called.
