wd45 trans
Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fields Quote  Post ReplyReply Direct Link To This Post Topic: wd45 trans
    Posted: 19 May 2011 at 6:58am
I have a wd with a late style trans. It locked up in gear. Hapened once before. I got it loose by taking the lever out and lining up the openings where the lever goes. Can't get it to do that this time. Been stuck for a year now.
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2011 at 8:22am
Is it possible there is a bind on the tranny, like the tractor wants to move, and the wheels are holding it back, i.e. do you push the clutch in while trying to move the forks?
Other possibility is the rails are rusted, my 17 was missing the rubber boot, meleted in a fire, and water ran in the shift tower, and put just enough rust on things to freeze the shifter.  Taking the shift tower off the 45 isn't too big a job, so that would be my next step.  My best guess is that's your problem, but it could be something broken as well, in either case you have to take the top off the tranny.
Still in use:
dcso View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dcso Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 5:23pm
i was reading one of your posts about removing a wd45 shift tower. whats the best way to get it back in?
thanks
ted
ALinIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALinIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 7:04pm
Fields - If you got the tower off and all is correct(The shift lever works properly and nothing is bent).  Take the shift lever and shift it in reverse.  Align the shift collers so the trans is in reverse.  Then just carefully reinstall the tower.  Drop in a couple of bolts and test by turning one of the rear wheels.
dcso View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dcso Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 8:14pm
thanks a bunch
ted
