WD45 Hyd. Pump Blockoff Plate
Jeff(WD45-SATX-TN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WD45-SATX-TN) Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Hyd. Pump Blockoff Plate
    Posted: 18 May 2011 at 1:19pm
Does anyone have a block off plate that covers the location of the hydraulic pump? I am also looking for the plug, or cover that goes into the belt pully location.
Thanks
Jeff
1954 WD45 NF "Iron Tater"
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2011 at 1:34pm
Buy a piece of 3/8 flat stock big enough to cover the hydraulic pump hole and drill holes to match the tapped holes in the tractor.  Could do the same thing for the belt pulley delete plate if you can't find one.
