8030 tach
Steele View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steele Quote  Post ReplyReply Direct Link To This Post Topic: 8030 tach
    Posted: 17 May 2011 at 9:55pm
My tack and hour meter is not working.  Thought the sending unit was bad so ordered a new one and installed, no luck.  Does it matter what wire gets connected to which wire on the harness?  There are two wires that appear to be the same color.  Is there a way to test the sending unit?  Also where do I go from here as far as testing?  Seems funny that the hour and tach both quit working is why I figured it was the sending unit.
thanks
Steele
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2011 at 7:02am
Make sure you are getting 12V to tack.   MACK
allisorange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisorange Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2011 at 7:14am
       Listen to Mack, When the one on are tractor quite it was a bad connection and no power to the tach.
                                        John Carlson
bill2260 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bill2260 Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2011 at 10:49am
I have 8030 too. Tach works, hour meter dosn't. Is there anything to try to get it to work. Repair manual said something about check the ground. Would the tach and hour meter have a different ground? I noticed some wires grounded on the steering column, but they came up from bottom of tractor, not down from the tach hour meter. Bill
jb from md View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jb from md Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2011 at 8:07pm
remember that just because the sensor is new doesnt mean that its a good one! we had 4 gm blower motor resistors in a row that were bad at the garage the 5th one was good ,took a while for the parts guy to believe it, there is many times this happens with new parts. check the wires from the sensor to the tach for continuity to make sure you dont have a broken wire, then if they are good its probably the tach- JMO-...Jb
8050 FWA, 190XT, 185, Styled wc, Unstyled wc, (2)C, (2)WD45NF, WD45WF, WD,416h, 716h, 312h, 8070 pedal.
This page was generated in 0.115 seconds.
