Comparison between D21 abd 220
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Topic: Comparison between D21 abd 220
    Posted: 17 May 2011 at 3:59am
Comparison between a series II D21 and a 220.
Any differences between the drive trains etc.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2011 at 5:18am
Fred. The big difference is in the rear end and final drive gears. A 220 weighs about 1500 lbs more than a D-21 and has a 5" longer wheel base. 220 bull gears have a bearing on both sides and bigger axles.
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2011 at 7:42am
220 is improved version of D21. 21's look cool and are "famous" but I'd not trade my 220 for one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2011 at 11:12am
I've heard pretty much the same. 210-220 transmission case is bigger and stronger also designed for a ft wheel assist option unlike a D21.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2011 at 2:36pm
transmission is identical except the filler and lube fitting on side. rear housing is where the difference is.
acd21man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd21man Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2011 at 8:12pm
i guess im lucky cause we have both but the 21 is just in the shed ready to be redone the 220 is my fav she wont spin a tire pulling and thats with no water in them just walks on
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2011 at 9:36pm
We have both as well, and I tell you what, I love the D21 styling, and I used to love that old girl for tillage, let the 7060 play with the 3pt impliments.  But we picked up a 220 a couple years  back, and I am in love again.  I am sure if you hooked drawbar to drawbar, the 220 would grunt and walk, the D21 even though similar weighted would just slide and wonder!!!  I will tell you this, they sound exactly the same, and that motor along with the hydro steering makes the sweetest sound in the world!!!!
Still in use:
