7080 won't move
jeffnil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeffnil Quote  Post ReplyReply Direct Link To This Post Topic: 7080 won't move
    Posted: 16 May 2011 at 8:25pm
bought a blown 7080 for wife to pull with, put in n6 motor and double sprung torque limiter. tractor has power steering, hydrolics, and brakes but will not move. i can go gear to gear in transmission with clutch left out with very little grinding. Where do I start? sorry for rambling, not a lot of sleep last couple of weeks.  thanks for any ideas
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2011 at 9:18pm
Well, since you know the limiter is good, I would suggest the high low range cable, or the small park cable, if either are broken or way out of adjustment, the two speed after the transmission isn't going into gear.  Do you know if it moved before the motor was blown?
HTH
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2011 at 9:19pm
Splines are ripped out of the low range clutch housing of the Power Director clutch.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2011 at 9:46pm
Story goes, this tractor was going through the field pulling a field cultivator, and suddenly threw a rod out the side of the block. So I gotta think it was drivable before. Dr, could the engine locking up ripped splines? I dont really recall this one being locked up though. Will have to check it out. What about inching pedal? Ed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2011 at 10:00pm
Verify the clutch valve has pressure...195-205 psi minimum.  If the floor buttons stay in "hi" when depressed and returns to low button when the clutch pedal is pushed in, the pump is probably working OK.  If the torque limiter wasn't seated after installation, the disc probably isn't perfectly centered and that will finish off splines that are worn to begin with.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2011 at 7:01am
There are some large O rings in your PD clutch area that when they get stiff you will have nothing when you let he clutch out.  That is partly why my 7080 is split now.
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2011 at 7:19am
I have a 7050 that just quit a couple weeks ago, but if you have some grinding thats more than Ive got. I havent had time to look into mine so I cant be of much help but it does sound similar to my problem. Would the piston seals in the PD like victoryallis said leak by enough pressure to keep them from grabbing?
