Wanted to rent
BiG210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BiG210 Quote  Post ReplyReply Direct Link To This Post Topic: Wanted to rent
    Posted: 16 May 2011 at 3:47pm
 Anyone have a hovercraft to rent in ohio?  Must be able to pull 6 row planter let me know thank you!!! :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2011 at 3:54pm
If it's that bad out your way maybe I should have bought some corn this spring. Most of the corn around here is at least 2 leaf stage but could use some warmer weather about now.
dave63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave63 Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2011 at 4:49pm
I saw a picture of a Halicoptor rigged with PTO to a manure spreader and he was spreading manure. I think the person that put the photo together was trying to spread something as well.
The universal answer to all questions is yes, how much do you want to spend?
Teddy (punchie) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Teddy (punchie) Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2011 at 5:08pm
Western PA wet all spring and now it is even wetter.
Ac D-19, a Number of WD's, One WD45, Two 444 balers, Ac plows and etc.
Andrew(southernIL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew(southernIL) Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2011 at 9:06pm
Talked to a guy Saturday that has a couple hundred acres planted but still has 1100 acres under water and some of it was still 15 ft deep on top of it. So guess he needs a submarine to pull a planter.
If fishing is a sport your looking at an athlete
