AC pwered Genset |
Post Reply ![]() |
Larry(OH) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Shreve Ohio Points: 1577 |
![]() ![]() ![]() ![]() ![]() Posted: 16 May 2011 at 3:10pm |
Our company is offering this unit up for sale. Any ideas what the engine is (or what it will fit into)
'40 WC puller,'50 WD puller,'50 M puller '65 770 Ollie
*ALLIS EXPRESS contact* I can explain it to you, BUT I cannot understand it for you!! |
Tony.Or ![]() Orange Level ![]() ![]() Joined: 18 Mar 2010 Location: Oregon Points: 1498 |
larry There should be a tag on engine , it will tell the story . We need model number to figure out what it is. Tony
DonDittmar ![]() Orange Level ![]() ![]() Joined: 15 Sep 2009 Location: MIllersburg, MI Points: 2485 |
By the way the oil cooler is it sure looks like a 426....but should have the tag to verify
1968 D15D,1962 D19D Also 1965 Cub Loboy and 1958 JD 720 Diesel Pony Start |
i will see what I can get. I only have pictures of it and have not seen in person
Kcgrain ![]() Orange Level ![]() Joined: 24 Sep 2009 Location: Wisconsin Points: 774 |
Its a 426 engine same time frame as the d-21 210 220
amac ![]() Silver Level ![]() Joined: 11 Nov 2010 Location: Kalona, IA Points: 249 |
How much are they asking for it?
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21096 |
I'd say 210/220 because of the TO-4 "B" turbo and I think a deep oil pan with crank driven pump?? ...might be a place for tractor hydraulic pump to mount??
I just got some info on the engine. They say the tag says Model # 3500. Order number is 1-7451-63281
They said it needs a rebuild because of some bad blow by and water in the oilpan
No one has bid on it yet. It is a 600.00 starting bid. What do you guys think??
On one that vintage they only had two Orings on the sleeves....that'd be my guess.....as long as they didn't spin a crank brg from not catching it soon enough, it should be an inexpensve fix.
is that a 210/220 or 21 then
All three only had two sleeve Orings.
DaveKamp ![]() Orange Level Access ![]() ![]() Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 5892 |
My opinion is that gensets of this size and quality are bargains beyond all belief! People frequently go out and buy little air-cooled rattletraps, and pay way too much to have them hooked to silly little emergency panels, when they could've had much more substantial machines suitable for whole-house transfer... for much less money. Yeah, larger machine uses more fuel, but if you live in a location where cold winters occur, you can win BACK most of that fuel-consumption penalty by tapping the cooling system, and diverting from radiator to a heat-exchanger, and pipe hot water into the house for heating, thus getting bettern' twice the energy recovery from each gallon of fuel burned. That's exactly what I do with my trio of generators.
Windings in that generator head are made of the best copper on earth, the genhead can likely be wired for any power output you'd like... single or three phase, 208/125Y, 120/240, 480/277Y, 230 Delta... whatever suits you best... and it has serious protection circuitry and durable electronics, not something that'll blow up and die when an electrical storm strikes close-to-home. Even with a marginal engine, $600 is a hard pricetag to beat... |
Post Reply ![]() |
