D17D on its way home
BrianC,Ont View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Topic: D17D on its way home
    Posted: 16 May 2011 at 2:30pm
I just talked to a buddy of mine, and he has the Series III D17D on the trailer on the way to my place. It is the one that I posted back in Feb, that was for sale in Bowmanville. It was sold when I went to look at it, but the guy that bought it didnt want to pay to get it hauled home. Paid for it and never heard it run. The guy pushed him to start it. He says it runs nice, but lots of blow by, which I already knew. It has either an Allis or Henry loader and 8 pie weights. Will post pics when I get home.
35WC on steel, B with belly mower, D17 puller, D15 Series II puller, D15 Series II with loader, 608 Lawn Tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2011 at 2:34pm
I am going to restore it and put the Henry 305 loader I have on it. I would like to make it a high crop. Was there any thing to differeniate a high crop and a standard tread. as far as serial # go.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2011 at 9:47pm
Hi Brian, nice to hear you got that tractor.  I remember seeing the ad.  Thought about getting it, but realized I had enough money pits to look after first!
Good luck with it.  They are a nice smooth engine.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2011 at 5:30am
Brian,  D-17 High crops prior to series IV were all built by Tompson. I think that you want to make your series III a High Clearance. You need to find 38" PS wheels from a MF 65 High Arch and long spindle front axle. The front will be the hard part. This is what I did with my Series IV diesel.
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2011 at 5:46am
Like Calvin says, I have a MF65 high clearance and the rear hubs and wheels are identical. I think you will also need a pair of real wheel spacers . Or at least my D-17 high clearance has them.  Dave.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2011 at 8:03am
The 38's bolted right on my D-17 without spacers the same as the originial 28's. I have a 60" row spacing with enough clearance to the fenders. Dave your spacers may have been necessary for a maximum wide row spacing.
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2011 at 12:21pm
I believe the differences are
taller front spindles
38" rear wheels
6" axle extensions
different fender mounts to go along with the axle extensions
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2011 at 8:15pm
Matt, I've seen the 6" axle extensions on D-14 and D-15 tractors but never on a D-17.
Are you talking about the main cast axle extension similiar to the D-14/15 or a hub extension where the wheel center bolts on? I'm open to learning something new everyday!
Edited by Calvin Schmidt - 17 May 2011 at 8:15pm
