D17 aftermarket 3 pt
fwo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fwo Quote  Post ReplyReply Direct Link To This Post Topic: D17 aftermarket 3 pt
    Posted: 16 May 2011 at 6:30am
We just got a D17 IV and need a 3 pt.  What are the choices?
FWO in Ohio
Kindest regards,
F. W. Owen, Homerville, Ohio
http://www.HomerProduceAuction.com
Owenlea Holsteins
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2011 at 6:36am
Saginaw tractor has them....put one Dad's D17I. Tony Carbaugh also has them listed on his site. So does Jim Danforth
1968 D15D,1962 D19D
Bill Deppe/AC Salvag View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Deppe/AC Salvag Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2011 at 7:43am
May have one from a salvage tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2011 at 9:37am
Think about what you want the 3 pt for.If you want to only use the 3 pt and want to keep it on there buy the "Saginaw model" that is harder to get on and off.You won't be able to use the snap coupler bell for snap coupler equiptment as easy with this style.
If you want to take it on and off and use both SC and 3 pt equiptment buy the other version that has a SC loop and arms that connect to lift latches.
Depending on model of adaptor the traction booster may not work,Big deal if you are plowing or heavy field work.
Some models have a cross bar that can hit PTO shaft on mowers.Some crossbars can be removed for mowing or PTO work
Plenty of vendors on here sell the different styles of 3 pt adaptors on here,Call a few of them and ask lots of Questions; Cost,Shipping,Waurentee,Paint,Cat 1 or Cat 2,Where are they made,Photos,Can you use original drawbar.
For a new one 400.00 - 800.00
Have seen them sell at auction 100-150
I bought one here from a vendor on here.It works OK but I wish I would have asked more questions and done more research.
Tony.Or View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony.Or Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2011 at 3:20pm
You have  two  choices  from me .  Snap-coupler - wishbone  style , or  Draw bar mount.  Pictures  on web site  www.tonystractors.com        Just  depends  on what you want  in a hitch.         Tony
Greg_WJP_(WI) View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Greg_WJP_(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2011 at 3:28pm
If your heart isn't set on aftermarket, I see Joe is selling one in the classified section.  http://www.allischalmers.com/new/forum/forum_posts.asp?TID=30832&title=fs-d17-iv-factory-3-point
Thought I would mention it.
Edited by Greg_WJP_(WI) - 16 May 2011 at 3:29pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2011 at 3:45pm
I would go with a factory 3 point like Joe has for sale.
se iowa picker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote se iowa picker Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2011 at 9:41pm
We put a three point off a 185 on our D17 series IV and have had really good luck with it but once its on its on and there is no going back without full reconversion.
