Turning Up A Pump On 8030
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Topic: Turning Up A Pump On 8030
    Posted: 14 May 2011 at 5:09pm
 We have an 8030 that seems to be lacking power. Thinking about taking pump in to get checked out. I was wondering if the 8030 & 8050 had the same engine. If that is so than we could turn up the pump to put out 150 hp. What do you think?
Thanks & God Bless
Dennis
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2011 at 5:16pm
8050 had an intercooled engine (670I), don't think the 8030 did, pretty sure it had the 670T (only turbocharged).
Hurst
1979 Allis Chalmers 7000
5800 Hours
Carl(NWWI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2011 at 7:26pm
Should have the same pump, should be a American Bosch Model 100, 13mm pump, unless 8030's & 50's had 11mm, not sure, but anyway, the top cover on the pump, should be 4 1/4 inch bolts, take them out, pull cover off, the screw will have a 7/16 nut, and have a flat head tip on the end, loosen the nut and turn the screw out a 1/2 turn, or 1 turn, depends on how much power you want, i think its 50hp and turn, or in that area.
Good Luck, Carl
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2011 at 9:30pm
ALL model 100's used on 8000 series AC's were 10MM.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2011 at 10:31pm
I was told the 8070's had 13's
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2011 at 11:27pm
Hurst
Correct.  If my memory is correct, the 8030 only had a 2 pinion differential while the 8050 had a 4 pinion.  I can't remember if the planetaries were the same or if the 8050 was also wider than the 8030.  Increase the hp at your own risk.
Mark
GTH-L Simplicity
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2011 at 11:45pm
Sorry, 9.5mm I guess, so they must call em 10mm. still the same to turn em up though, still not sure on how many horse a turn is.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2011 at 8:19am
8050 has a larger (more tooth length) ring and pinion, 4-pinion differential and final drives that are the same width, but faster gear ratio. If the injectors have 4,000 or more hrs on them, replace the tips before you start increasing the fuel delivery of the injection pump. When those Bosch injectors wear, they will increase the smoke levels AND the HP drops, and increasing the fuel delivery only makes the smoke heavier and does not increase the HP of the engine....been there.....seen it!!  Adjust new injectors to 3600 psi instead of 4,000 psi plus as the book says.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2011 at 8:48am
 This 8030 does not smoke at all. When you load it down the exhaust stays clear.
Thanks & God Bless
Dennis
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2011 at 10:13am
Will these engines start better in cooler weather if the injector pressure is set at 3600 psi
instead of 4000 psi.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2011 at 10:22am
the head in your pump may be worn out! We have seen several M100's lately that have worn hyd heads, so fuel delivery is low, but they still start. have you had tractor on a dyno? sounds like the pump is due for rebuild.
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2011 at 11:51pm
@4900 hrs my M100 was shot.No gov action down low,lots of smoke and wouldn't start hot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2011 at 8:48am
IH used these pumps befor AC and they called them (2500 hour pumps).  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2011 at 9:18am
I wonder if today's ultra low sulfur fuels are causing more pump and nozzle wear in the older units not designed for ULSD?
Mark
GTH-L Simplicity
