WD45 hydraulic control linkage help...
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Topic: WD45 hydraulic control linkage help...
    Posted: 13 May 2011 at 10:41pm
Could someone post a pin of they're hydraulic control linkage down by the pump? I hooked it back up how I remember it, and now I can't raise the lever even half way.It's as if something is in the way? Usually if I play with something long enough and look at it hard enough, I'll figure it out. Girlfriend's the same way. I played with if for the first half of the dar yesterday, then after I gave up and started working on the front end she started playin around with it and couldn't figure it out either. She got her dad's parts book, and it shows the thicker rod comming off the lever, but not where it goes on the pump. It goes in the second hole back from the front of the pupm and the skinny one goes to the first hole correct? r the other way around? Thanks.
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2011 at 7:39am
Hope this is enough to help you
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2011 at 9:52am
Perfect! Thanks a bunch! I see what I did... Jeesh looks like your batt. box has seen better days..did you have the corrosion from the acid on the cast like I did?
German Shepherd dad
#WD234847
#WD88193
