WD 45 front wheel bearing
rossinmich View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rossinmich Quote  Post ReplyReply Direct Link To This Post Topic: WD 45 front wheel bearing
    Posted: 13 May 2011 at 8:04pm
Anyone know the part number for a new wheel bearing. Mine has developed quite a whobble and I think it needs a new bearing. Wheres a place to order a good one?
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2011 at 8:08pm
I believe there is a inner and a outer bearing. You need to find out which one. Ryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2011 at 8:17pm
Ryan is right, there is an inner and outer cup and an inner and outer cone. If you take it apart and clean things up, repack the bearings you can probably eliminate most of the wobble by tightening the bearings up. If the cone falls apart when you clean it, get the numbers off the part and go to your local bearing supplier.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2011 at 8:22pm
Norm at Norms toys . Has an ad here.Helped me out with my D-17 front wheel bearings .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2011 at 8:25pm
I'm kinda dealing with this myself right now. There is a seal also on the inner side. If you figure out which bearing it is I can give you a timken part number. Ryan
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2011 at 8:28pm
   our kits include seals and all bearings   1-800-254-3116
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2011 at 8:38pm
old Allis Part no for tricycle and wide front 209926 bearing outer, 209983 cup outer, 228458 for the
package.
222214 bearing inner, 209987 cup inner, and book says 228458 for package, but I question that as that us the same part no as the outer package
seal/retainer
202104/202103
Edited by LouSWPA - 13 May 2011 at 8:42pm
I am still confident of this;
Wait for the Lord;
