190xt series 3 leaking hyd oil
dustinmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustinmo Quote  Post ReplyReply Direct Link To This Post Topic: 190xt series 3 leaking hyd oil
    Posted: 12 May 2011 at 9:32pm
I have a series 3 xt that started leaking hyd oil out of the belly @ the inspection cover and the hole at the bottom of the clutch it started 2 days ago after a good work out with a 12 shank chisel plow and 40 acres, anyone have any ideas before I start looking, I first thought it was the rear main, because she is new from top to bottom in the engine with about 3 light hours on it when I noticed it, but today I looked at it while dripping and it was hyd oil, and yesterday it took about 2 gal of hyd to fill it up, thanks, Dustin
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2011 at 9:36pm
Seals leaking on front of torque tube shaft. Split at back of engine and make sure there is no end play in shaft.  MACK
