Fluids and Qtys for D19 Tractor-What are they?
nowaktj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Topic: Fluids and Qtys for D19 Tractor-What are they?
    Posted: 11 May 2011 at 7:37pm
I left my manual 2 hrs south of here.
Can anyone tell me the fluid type and qty in quarts for:
  • Hydraulic System:
  • Final Drives:
  • Transmission:
Thanks in advance,
Terry
D19D, D17D, WD, WC, Snobee, #83 Plow, SC Blade, 14' disk, 400 series planter, B , Terra Tiger, M Dozer w/Baker Blade, TL-12, 42S Grader, G
Tedin NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tedin NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2011 at 7:53pm
Tractor Data book says
Tran and diff 32 qts
Power dir hyd 22 qts
Final drive 8 qts each
The book doesn't say type of oil, sorry
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2011 at 8:04pm
I know you can use modern Hytran in the hydraulics. Pretty sure it can be used in the P.D. Pretty sure the trans originally had 80-90. Finals in a D19 I would expect to share the same oil as the trans.
