Where to buy G tool bar gauge wheel tires
oldironguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldironguy Quote  Post ReplyReply Direct Link To This Post Topic: Where to buy G tool bar gauge wheel tires
    Posted: 10 May 2011 at 10:23pm
At an auction today I bought a barrel of Allis G cultivator parts including a couple of gauge wheels for the 60" double tool bar but they have no tires.  I think the tires should be solid rubber like planter press wheels. Does anyone know where I can buy just the tires?  They are labeled item 2 in the catalog...Allis part Number 317985.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2011 at 8:27am
I don't know the dimensions but look at Shoup or call them. Their on line search engine isn't all that good. www.shoupparts.com, maybe Sloan Express www.sloanex.com. You'll be looking for planter gauge wheel tires, planter press wheel tires, drill gauge or press wheel tires, and cultivator gauge wheel tires.
Just search for tire on Shoup. My guess is that its at:
http://www.shoupparts.com/product/default.aspx?id=13888 but they don't show a picture or dimensions.
Gerald J.
contrary_farmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote contrary_farmer Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2011 at 8:41pm
I have a pair that someone cut off the wheel without knowing you just have to unbolt the two wheel halves.  I haven't found a good way to fix that.
They're not solid rubber and I looked all over last year for a pair with no luck.  I don't believe they are a standard size which doesn't help the search.  Like everything else on the "G" it's so small.
junkman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote junkman Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2011 at 8:50pm
Post me a measurement And I will see if two I saved in a load of junk might accidentally be what you need. (Rim size and width)
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldironguy Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2011 at 7:01am
Thankss, guys.
The rims are split down the middle and the two halves can be separated toinstall the tire.  The rims measure 6 1/4" in diameter x 2 1/4" thick.  Let me know if what you have will help.
Dick
Post Options Post Options   Thanks (0) Thanks(0)   Quote junkman Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2011 at 8:32am
I looked at what I had and they were 5 3/4 x 2, so not quite the same. you might look and see if they make a pneumatic tire that will fit like the ones on the zero turn lawn mowers.  I will keep my eye out for you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldironguy Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2011 at 4:16pm
Thanks everyone.
Yes, please keep an eye out for me.  I will stop and Fleet Farm and see what they have for both inflatable and caster wheels.  Maybe i'll hust have to replace the whole wheel,d hub and tire.
