Reflaring Power Steering Line-Is it possible?
nowaktj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Topic: Reflaring Power Steering Line-Is it possible?
    Posted: 10 May 2011 at 4:52pm
I have a leaky power steering hose (psi side) on my D19.  I have identified that it is the flare that is bad.
Has anyone tried reflaring these with the standard flaring tool you can get at auto parts stores?  The diameter is 1/2" so it fits.  Does a guy need to apply heat to help get the double flare that is needed?
Thanks in advance
Terry
D19D, D17D, WD, WC, Snobee, #83 Plow, SC Blade, 14' disk, 400 series planter, B , Terra Tiger, M Dozer w/Baker Blade, TL-12, 42S Grader, G
Protrucker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Protrucker Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2011 at 5:40pm
No heat normally needed, but there is a special tool for making the double flare. I've got one of the tools. They're not real expensive or difficult to use.
