Not my day...again!
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Topic: Not my day...again!
    Posted: 10 May 2011 at 1:34pm
I went up to the school garden to seed in some wheat with my little allcrop and D14.  I always just put the bags of seed in the drill...so I did.  I thought I would mark out the outside of the field before I dumped in the seed. Well, one bag caught in the feeder wheel thingy and before I caught it it had wrapped up enough of the stringy stuff from the bag to bust up at least 2 seed cups....then sprayed seed all over the ground.  Looks like that drill is done for the year, as it looks like a lot of hours to take things apart.  Anyone have any used parts they want to get rid of?
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2011 at 2:16pm
If I accept the sunshine
and warmth,
then I must also accept
the thunder and lightning.
-Kahlil Gibran
Faith isn't a jump in the dark. It is a walk in the light. Faith is not guessing; it is knowing something.
"Challenges are what make life interesting; overcoming them is what makes life meaningful."
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2011 at 4:21pm
sounds like your luck runs about like mine!!!     :(  Darel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2011 at 11:30pm
Well  today was a little better, nothing broke, got the stupid oil filter on my D17D to stop leaking, and took a closer look at the drill.  A little time with a map gas torch melted down the seed sack material and I was able to pry it out with a screwdriver after it solidified.  Looks like one exploded seed cup needs replaced, may be able to do the old duct tape thing on it for now.  Probably should replace a couple of others that popped the rivets....has anyone replaced them?  How big of a job to pull the shaft out?
Edited by Eldon (WA) - 11 May 2011 at 11:32pm
ALLIS EXPRESS!
This year:
