CA vs WD/WD45 SC loop size
Murph-NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Topic: CA vs WD/WD45 SC loop size
    Posted: 09 May 2011 at 9:24pm
Do the SC loops for CA implements interchange with WD/WD45 implements?  Thanks in advance.
'41 C w/Woods L503 mower, #3 mower, 2-way plows for C
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2011 at 9:56pm
the loops are all the same. Many of the implements have slight variations from the WD to the  CA. Bob
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2011 at 9:56pm
yes they do. most of the WD snap-coupler implements will work with the CA. You will lack HP.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2011 at 7:48am
Thanks guys... I'm actually just asking because I've got a chance to buy a loop that I'd like to add to a planter.
RichinWis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichinWis Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2011 at 8:14am
The loops are the same but the hitch lenth can be different and cause you grief, like the grain drill for a CA has too short of a hitch and the upper links are closer together than WD45 and D series. Same with SC blades
This page was generated in 0.168 seconds.
