Fat fingered my message in box
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Topic: Fat fingered my message in box
    Posted: 09 May 2011 at 8:55pm
Okay, so I was being a good forum member and deleting messages out of my in box. Yep, deleted a couple that I needed to keep. The one that I don't have and need the most is from Bud(WI) about the 80R sickle mower part. Sorry for the inconvenience and thanks for the help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2011 at 8:44am
You know, you are not the first to do this.  The way you delete PM's should be changed.  Instead of the delete all (which is the problem), there should ONLY be a delete only the checked ones.  Where would someone suggest this change??  Hint-hint.
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2011 at 1:12pm
Uhhhhh - in the Forum Talk section?
Good judgment comes from experience. Experience comes from bad judgment.
From listening comes wisdom and from speaking comes repentance.
Wise men learn more from fools than fools from the wise.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2011 at 1:44pm
I went and posted it.  Sure hope something is done about it!!
MAYBE if enough other guys go and complain about it??
Edited by Ted J - 10 May 2011 at 1:45pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2011 at 2:48pm
I've done the same thing so now, if I have info I don't want to lose, I click on the "email it to me" link.
