onan generator
fatman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fatman Quote  Post ReplyReply Direct Link To This Post Topic: onan generator
    Posted: 09 May 2011 at 7:19pm
havent been on here in some time so here goes.
i need help with an old onan gen set i took out of  a old motor home.  i think it was a 1972.  any way its not drawing fuel ffrom my tank to the carb.  i cant find anything for the model no. i found,  4.00cklr/9470n  serial, 0271286871.
just from a quick eyeballing the pump looks to be about 2 inches around and maybe 4 inche tall.  it has one wire or vacuum hose besides the fuel lines going to the pump.
is it electric or gas????  if it is electric i can probably put after market?
let me know what s up or where to look.  thanks.
Tad Wicks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tad Wicks Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2011 at 8:45pm
fatman, whatever your pump is,(it could be an electric pulse pump, some Stewart Warner and Bendix pumps were single wire, but most have two wires, hot and ground) it is probably aftermarket, not Onan. Later Onans and Kohlers both used diaphragm pumps driven by crankcase pulse pressure. Find out if it is indeed electric, when working you can hear and feel them.   Good Luck; Tad
Post Options Post Options   Thanks (0) Thanks(0)   Quote fatman Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2011 at 10:25pm
pretty sure the pump is original.  it is the funny blue green color still.  that is the other problem it dont pump gas. so i cant feel it run.   i ll get the covers off and see where the other end of the vac hose or wire goes,  then i will determine what type a pump it is?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2011 at 1:50am
sounds like a bendix pump, some have a removable cover on bottom for fuel filter , new solid state pumps work better than the old ones that were point system pulse pumps.
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2011 at 7:21pm
sounds like an electric pump, should be controlled from under the shroud by an oil pressure switch if i remember right. you can replace it with a normal electric fuel pump and it is self grounding.
This page was generated in 0.523 seconds.
