D19 gas pulling tractor
wrbewley View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wrbewley Quote  Post ReplyReply Direct Link To This Post Topic: D19 gas pulling tractor
    Posted: 09 May 2011 at 5:02pm
I'm building a 262 to pull I am looking for ideas on a higher compression piston does any one have an idea of what could be used with the stock sleeves. I have diesel pistons but I think they are to tall.
Jim Hancock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2011 at 12:10pm
I understand so far that LP pistons will do.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wrbewley Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2011 at 4:25pm
I have been unable to find LP pistons, any sugestions where I could find some.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2011 at 7:57pm
Use a standard piston with a longer rod, or use the diesel piston with a shorter rod. Make any compression ratio you want.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2011 at 8:48pm
You can machine .200" or .250" off of the tops of diesel pistons and use a thick diesel head gasket....been there dun that many years ago.....don't remember the exact depth of material but it's between .200 and .250.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2011 at 10:01pm
I would guess you are going NA ? If turbo the diesel pistons won't take it.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote wrbewley Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2011 at 6:55am
I will be running na, I will be running it in the 4500lbs modified stock antique class, the tractor is actually a D17 diesel with a gas 262 out of a CII combine, I do have the pistons out of the diesel engine, so I will try shaving those pistons, I really didnt want to shave the block, how thick of a head gasket are you talking about, or do you just mean to use the diesel gasket.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2011 at 6:58am
Diesel gasket is much thicker than a gas gasket.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2011 at 9:38pm
Gas gasket is .035 diesels .065     MACK
ACD19farmboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACD19farmboy Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2011 at 9:42pm
haha u got the same idea as me man!!!! the hp of a D19 with the weight of a D17!!! this winter i will be building a D17 Diesel pulling tractor with a CII engine, but turned up and with a One-Ninety XT turbo!! POST PHOTOS MAN!!!!!!!      Cordel
Post Options Post Options   Thanks (0) Thanks(0)   Quote wrbewley Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2011 at 7:08am
I've been pullin this tractor for a couple of years with the diesel, but with blowing head gaskets and lack of power was never competative.  In the classes in ky we were never able to run a turbo. So i decided to build this engine hoping to hang with the Olivers with the bigger 6cyl that dominate the light classes.  Funny thing is i was told i could never get this tractor less than 5000lbs, she ways in just under 4500lbs now with very little stripped off of it, but i plan to weigh in at 4000lbs when i am finished.  If you need any parts for the 262D shot me a message i still have many parts off the old motor, including a good block. Will post pictures when tractor is done.
KGood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KGood Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2011 at 7:24am
Wrbewley,there is a combination using the cockshutt version of the same motor that is sleeveless and had a big bore but short stroke. You just need to put the 262 crank in it cause it's longer stroked. I don't remember if it was 280 or 290 something cube. I'd like to see one pull done up that way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2011 at 2:38pm
What kind of rule won't let you run a turbo on a tractor that came from the factory with a turbo? Nonsense!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote wrbewley Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2011 at 5:39pm
The tractor is actually a d17 which had the same motor as the 19 but it was not turbo, so according to our rules no turbo allowed on the 17.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2011 at 9:26pm
Blown head gaskets is no problem. Have been running 70 Lb boost on a 262 and have never blown a head gasket.  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote wrbewley Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2011 at 11:32pm
I thank the six cracks in the head had a lot to do with it, I was blowing gaskets about every two hooks.
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2011 at 5:44am
I would be interested in the block if it was closer
1968 D15D,1962 D19D
